D4 Weights
D4 Weights
noahthompson
Send a private message to noahthompson
I’m currently looking at buying 2 d4 to match my collection. Ones a narrow gauge with a blade and other one is wide gauge with a winch just need the rough weight of them. Narrow gauge is A 1949 and wide is 1956 [attachment=66747]8A2AA1CB-9E52-4420-8BC7-DE971623D198.jpeg[/attachment][attachment=66748]EE067116-FF05-4992-B58A-3EF08C0928A6.jpeg[/attachment]
Thu, Feb 10, 2022 10:27 PM
13,590 lbs with blade and hyd. @15,000 lbs with winch blade and hyd.
Thu, Feb 10, 2022 10:35 PM
GrantJ
Thank you received: 7
Look for the fenders for the one with the winch. The early D4s with Hysters needed a strong bracket that bolted under the fenders and went to those top two Hyster mounting holes. The brackets are about 4 feet long and on the rear are very heavy steel mounting lugs. Later D4s came with the rear case strong enough not to need the brackets. That photo appears to me to be a "U" series and I believe that it was somewhere in the U series that they changed the rear case. Good Luck, Grant..  I will try to get a photo of the brackets today and post.
Fri, Feb 11, 2022 10:16 PM
rax200
Hi Grantj,
If you look at this photo you will see the two mounts on top of the casing, this is what you need for the top mount.
The tractor is a D4 2T hope this helps.
 [attachment=66796]IMG_4436.JPG[/attachment]
Regards
Sat, Feb 12, 2022 4:36 AM
GrantJ
 [attachment=66809]20220211_144228.jpg[/attachment] [attachment=66810]20220211_144035.jpg[/attachment]RAX200, yes that is the bracket that is needed. The one that I have is welded to a long piece that bolts under the fender. I believe that it came off of a 2T originally but my dad had it on an RD4. I have the Hyster manual somewhere around here that I think shows the bracket with the long piece. I will have to find the manual and see if my memory is correct.                Grant.
Sat, Feb 12, 2022 11:54 PM
