d4 track pads
d4 track pads
Showing 1 to 9 of 9 results
kylerose
Send a private message to kylerose
Im sure i've seen a thread about it on here before but i cant find it anywhere, Im wondering how long D4 track pads stayed the same as far as bolt pattern or pitch . An example of what im talking about is ... could a d4 7u pad bolt on to a d4d rail , or could it work the exact opposite to that ? Thanks
Kyle
Tue, Dec 9, 2014 7:15 AM
Thank you received: 19
Pattern and pitch (6.75") stays the same but the bolt size changes. Can be 1/2", 9/16" & 5/8" bolting.
Tue, Dec 9, 2014 7:43 AM
OzDozer
Kylerose - There is only one D4 track pitch - 6.75". However the track shoe bolt size changed 3 times - from 1/2" to 9/16" to 5/8".
The bolt pattern spacings are the same all through.
You can fit smaller bolt hole shoes to chains with larger bolt holes by drilling out the holes with a carbide, or maybe even a good cobalt drill.
However those shoes are hardened to 60RC and that drilling is slow going.
It would be possible to fit shoes with larger bolt holes to chains with smaller bolt holes, by utilising thin sleeves inserted in the shoe holes, but this would not be recommended due to inadequate bolt head grip.
Shoe widths range from the 13" width that was original fit to the RD-4, right through to the 30" shoes of the low-ground-pressure option on the D4D.
Regards, Ron.
Tue, Dec 9, 2014 7:44 AM
kylerose
Reply to OzDozer:
Regards, Ron.
Thanks for the replies , im checking for a friend and he has a machine shop so it wouldnt be a problem drilling them out
Tue, Dec 9, 2014 8:01 AM
Reply to kylerose:
Some have reported better drilling result using a "bridge reamer".
Tue, Dec 9, 2014 8:30 AM
dick
Send a private message to dick
I have had very good luck with 3 or 4 flute core drills, drilling out a complete set of D7 pads without needing to have it resharpened before I finished.
Tue, Dec 9, 2014 9:44 PM
Steve A
Reply to dick:
Can anyone tell me if there's a modern track pad with the same spacing/pattern as was used on the Thirty. I need 1/2 a set of 16 inch grousers for my dads 30 project and have had no luck finding them. I will drill or make bushings if I need to.
Is there a chart of bolt patters for modern grousers ?
Thu, Dec 11, 2014 6:16 AM
Reply to Steve A:
Might be of some help...
Thu, Dec 11, 2014 6:33 AM
OzDozer
There's no modern pad which will interchange with the Thirty because the Thirty uses a square pattern for the bolts, and modern tractors use different width spacings for each row of bolts.
I'd say the best you could probably do is find some modern 16" pads, try them for general fit, and re-drill the bolt holes.
Thu, Dec 11, 2014 9:31 AM
Steve A
Reply to OzDozer:
This will help, I can hope a can find a modern pad with at least 2 of the bolt holes line up
Fri, Dec 12, 2014 9:18 AM
Earlcoate Charity Open Day
