D4 tool bar blade trunion interchange
Breadler
Hello everyone,
I am trying to determine if the 4 roller and 5 roller D4-7U use the same track frame / trunion bolt pattern spacing. Also, do D4C or D4D utilize the same bolt pattern? I recently acquired a set of tool bar trunions from a D4C, to add to my 5 roller 7U, however the bolt spacing seems different, with either the front 4 holes lining up, or the rear 4. Essentially the trunion plate seems to need about 1” of additional material between the front 4 and rear 4 holes….
Thanks much,
Breadler
D5C, D4-7U, D2-5U, D2-5J
Mon, Mar 30, 2026 4:13 PM
Thank you received: 291
This is interesting. TractorDon sold me a really nice TB setup from a 5 roller 7U and it bolted directly to my D4C without any modifications required (per my favorite wrench person). One would assume that they would all bolt up okay, however I have seen some guys put what appears to be 1” to 1.5” spacer between the trunnion and track frame on some machines.
Mon, Mar 30, 2026 11:20 PM
Perhaps time to bring out the magnetic drill and tap set.
Mon, Mar 30, 2026 11:21 PM
