D4 suddenly locked up, help
Showing 1 to 10 of 20 results
nickspalding
Send a private message to nickspalding
I have a D4 7j with a g series engine that I drug home last year. I finally got around this last weekend to try and get it going and now have some strange problem. When I got it, I got the usual "ran when parked last year" story, but both motors were free and I had to close the fuel when pulling it down the mountain because it acted like it wanted to start. This weekend I checked and both motors were still free, so I thought I would pull start it and make sure the motor ran ok before I messed with my arch-nemesis, the pony motor. When we pulled it with our D2 and I went to engage the clutch, it would almost stall the D2 and drag the tracks on the D4, even with the D4 in fifth gear and the D2 in first gear. I tried with my pickup and the same thing happened. I stopped and tried to turn over the main with a prybar on the front of the crank and nothing. Then I engaged the pinion and turned both the pony and the main over by the pony crank pulley. This worked for a couple times and then when I tried to turn the main over with a prybar it was stuck again. So we went back to the pony and now the pony will turn over with some difficulty and it seems like it is slipping the pony clutch. I pulled all the injectors and tried, still stuck. Then I put some PB blaster and diesel down the cylinders hoping it just had some rusty rings or liners. I am stumped, the main clutch feels good and since the main previously turned over and now seems stuck, it almost seems like something fell into a cylinder and is preventing it from rotating, but I doubt it. The next bigger tractor I have to pull with is a D8H and I am afraid it will just break what ever is stuck. On a side note I pressurized the fuel system and can get diesel up to the injection pump bleeders but not out of the injectors. It has held pressure like this for several days. But that is a small problem, I am more worried about the engine intermittently turning over. How do I disengage the pinion so I can narrow down the problem. Anyone have any ideas? Is it in the transmission?
Wed, Sep 12, 2007 11:55 AM
ol Grump
To disengage the starter pinion, pull the front floorboard cover. This will expose the little round plate on the left side of the bell housing. Remove the little plate and the pinion will be underneath. Reach in with a screwdriver and "pop" the pinion fingers loose, this should release the starter pinion from the main engine flywheel. This is also where you adjust the "kickout" of the pinion.
If the tractor rolls freely w/o the engine clutch engaged, I'd say the tranny is ok. You said you'd pulled the injectors and the engine is still either locked up or uncommonly tight. Sorry, but I'm out of ideas there. .maybe someone else on this board might have some notions. .
Good luck,
Paul
Wed, Sep 12, 2007 6:49 PM
Thank you received: 19
Reply to ol Grump:
Good luck,
Paul
It's early, I got my coffee......but I'm still a little "fuzzy" but here goes😉 😉
Your dealing with two separate issues:
The pony pinion needs to be disengaged as Ol Grump describes.
With fuel to the injector pump vents, you have fuel in the supply chamber but flow is not getting to the injector pumps and injectors for a couple of possible reasons. 1. The rack is stuck or 2. One or more lifters are stuck in their bore which prevents the pumping action.
Also what are you getting for transfer pump fuel pressure?
Take the side inspection cover off the injector pump and work the throttle to see what is or is not working. Usually a little nudge and your favorite penetrant will get the rack going (it is spring operated by the governor, not direct linkage)
A little prying and pen. lube of the lifters unusually gets them going again.
Wed, Sep 12, 2007 9:55 PM
nickspalding
My biggest concern is that I could turn the main over by hand and then immediately following could not. Is there something that would cause this to happen? I was pulling on it pretty good with the D2 and don't think it would be that tight if it only had some slightly rusty rings or liners. Is there something mechanical that would stop it from turning like that? Would the rack being froze up create that much resistance? When I try to turn the main with a prybar on the crank pulley, it feels like it has a small amount of play. The closest comparision that I can think of is the small amount of play in an automotive differential when you wiggle the pinion back and forth against the ring gear teeth. I am a pretty good size guy in my mid 20s and even with the decompressors open I cannot budge the engine. To pressurize the fuel system I hose clamped part of an inner tube with the valve stem over the fuel tank opening and charged it with a couple of psi. I have no idea what pressure the transfer pump is putting out as I have never had either the pony or the main running.
Thu, Sep 13, 2007 1:30 AM
Reply to nickspalding:
First off you need to get the starter pinion disengaged. So long as it is coupled you are trying to turn the pony through the pinion/flywheel gear ratio when attempting to spin the main. It would be at its highest ratio when the pony is coming up on compression. When it leaks down you are good to roll it over until the next compression stroke.
Once you are uncoupled, roll both engines over to see if there is a resistance point.
The last time I remember trying to pull start a D4 with a engaged pony the D2 could barely even pull it.
Thu, Sep 13, 2007 4:44 AM
NZCat
Send a private message to NZCat
Wild Guess - but could it be "hydraulic ing" on its own oil or some other liquid thats getting into a cylinder somehow ?? A hydraulic lock would explain how its not there, there and so solid (pun intended) . . . better than loose metal in a cylinder but you would think that using the decompression lever would clear it . . . could the decompression gear be playing up ??
Cheers - Foster
Foster Price
Southland, NZ
D2-5U #10200
Thu, Sep 13, 2007 11:51 AM
ol Grump
Reply to NZCat:
Cheers - Foster
One more thought on the engine "locking" up. .could it have happened that the air cleaner was off the engine long enough that little critters may have set up housekeeping in the engine?? Built a nest maybe in one of the cylinders? I wouldn't have believed if but a D4 7J engine I'm tearing/parting out had the water pump off and was sitting in a field for a few years before I got it. .and critters had set up house in the water passages of the head and block!!! You should have seen the stuff that I blew out with an air hose. .small pine cones, seed pods, fiberglass insulation, grass. .all SORTS of junk.
Just a thought. . .
Paul
Thu, Sep 13, 2007 6:44 PM
bobk
Send a private message to bobk
Reply to ol Grump:
Just a thought. . .
Paul
The pony could be locked from fuel. A D2 pony was locked at a show unloading even though it had been running the day before and the fuel had been turned off. Bad shut off valve. (also a poor float valve) With pinion ingaged, this would make it look like a solid stop. This condition was developed over night. Open both drain valves in the pony heads and see if anything drains out.
Just a thought, Bob
Bob Kroeker
Fri, Sep 14, 2007 2:20 AM
933scotty
Send a private message to 933scotty
Reply to bobk:
Just a thought, Bob
You might pull the valve cover and check for a stuck or worse bent valve . We had an off brand that had a stuck valve that ended up broken off and lodeged in the head of the piston when the owner just pulled bigger and bigger tractors untill it broke the head of the valve off !! Good luck Scotty
Fri, Sep 14, 2007 4:52 AM
Philip
Send a private message to Philip
Reply to 933scotty:
I bought a 3-53 Detroit that sat for 10 years. I had to use a pry bar on the flywheel after removing the starter. The leverage that is possible between the flywheel teeth and and the flywheel housing can be pretty impressive. Material that gets in through an open valve as previously mentioned can stop a piston near TDC. I had a D318 once like this. It's possible that an engine is free at first but when the pistons move up into the heavy rust on the liners that they seize. Phil😊
Sun, Sep 16, 2007 5:18 PM
dead axle
Send a private message to dead axle
Reply to Philip:
This may be too little too late but I bought an old Cat 15 years ago and while test driving it the engine quit and would not turn over. It turned out to be a frozen master clutch throw out bearing.
Tue, Sep 18, 2007 9:55 AM
