D4 starter clutch discs
Arrow Jimmy
Send a private message to Arrow Jimmy
I'm in the process of rebuilding my starter unit. I see that it uses copper and steel discs. There are heat marks on all the plates. The copper ones are quite hard. Should I anneal them? (heat to red hot, then quench in water)
Mon, Sep 20, 2010 8:19 PM
Never have attempted to anneal the plates. Think you'd have a problem with warpage. I'd be looking for new or good used replacements.
Tue, Sep 21, 2010 12:33 AM
gemdozer
Thank you received: 12
I am still have some good used cluch discs and plates for poney startor cluch
Tue, Sep 21, 2010 4:26 AM
Arrow Jimmy
Reply to gemdozer:
Thanks guys. I have cleaned up the discs and will try them as is. I suspect they were run without oil sometime in their 57 year life.
Tue, Sep 21, 2010 8:48 PM
