D4 Starter
D4 Starter
steamroller
Send a private message to steamroller
I have a 1949 D4 and it has a pony motor which runs but I have problems starting it because the carburetor is problematic. I would like to convert it to a starter,I would like to know what I need to make this conversion work. I know I need a template for the hole.I think the starter gear needs to be replaced to a reverse gear? where can I get instructions about this? Thanks
Fri, May 17, 2019 12:16 AM
It's easier and cheaper to clean and repair the carb, fuel lines and clean and coat the gas tank, it will run likes it's supposed to.
Fri, May 17, 2019 1:57 AM
55HT4
Send a private message to 55HT4
There are kits for direct start conversions here: http://www.auto-lec.com/directstart.htm
Fri, Jun 21, 2019 4:56 AM
| Kingaroy, Queensland
