D4 special tools part number
Jimmy977
Send a private message to Jimmy977
Hello folks, wondering if anyone would have tool part number for D4 7u steering clutches and pinion press pull shaft adapter?
Sun, Sep 8, 2024 9:25 PM
side-seat
5F5038. Originally 7S8431 was the number. I made one but it is a little tricky because the springs are not divided equally on their circle. General Gear sells one too if you don't want to attempt fabricating on yourself
Sun, Sep 8, 2024 10:58 PM
Jimmy977
Side-seat I plan to buy one of those tools from general gear. The other tool I'm looking for is an adapter that screws onto steering clutches shaft and also pinion gear shaft. It can be used with a puller to adapt puller leg to either shaft.
Mon, Sep 9, 2024 1:25 AM
side-seat
Reply to Jimmy977:
Just looked trough some pictures of the last time I was into D4 steering clutches but can' make out the thread size on the ends. Perhaps 1"-12 or 14 TPI.
Removal: all you need is a suitable bar puller for example: OTC 927 or 938 with some B7 all thread and heavy washers and nuts hollow hydraulic ram  and sledge hammer to pull the steering clutch packs.
Installation; All I did was weld some Gr8 heavy nuts together to adapt to the all thread 1"-8NC I use in my 30T hollow ram to press them back on to specified tonnage. I also made a spacer or standoff out of some seamless tubing so there was enough room for the nuts to do their push pulling.
Funny thing; My pictures have at the time, my 3yr grandson using the port a power pump pressing the clutch packs back on. He's 6 now and has just finished rebuilding his first Kohler 12hp engine on an old Cub Cadet tractor a friend gave him.
Mon, Sep 9, 2024 2:41 AM
Jimmy977
Reply to side-seat:
I do have a 17 ton crossbar puller. I'm considering buying a hollow ram and pump to do this work. You're grandson getting an early start on building up his bank of knowledge.
Mon, Sep 9, 2024 2:55 AM
Thank you received: 77
Reply to Jimmy977:
Jimmy, I used a hollow ram when I did the 5U which enabled me to both remove and install the hubs
Mon, Sep 9, 2024 7:24 PM
Jimmy977
I will plan on purchasing a hollow ram. I spoke with my local caterpillar dealer about rebuilding steering clutches. $195 an hour. Seems well worth it to buy tooling.
Tue, Sep 10, 2024 8:26 AM
Reply to Jimmy977:
I had my local machinist turn down a couple of adaptors and bought some threaded rod etc. to make up the pulling arrangements. I bought the hand pump with the ram that includes a pressure / tonnage gauge so I could see how much I was pressing the hubs on. The D2 snuck in using 20t equipment (Hydrafore) but you might need a bit more for the D4?
Tue, Sep 10, 2024 7:01 PM
Jimmy977
I'm planning to purchase at least 30 ton hollow ram. I own a 977 20A ,which is D6 equivalent, I expect I might be doing steering clutch work on in the future. Makes me wonder if 30 ton ram would be sufficient for D6 size work. I have not checked if these bigger hydraulic ram might have trouble fitting in bevel shaft compartment of a smaller D4. For working on pinion shafts. I suspect I will just purchase a 30 ton and figure d6 out in the future.
Wed, Sep 11, 2024 12:10 AM
