D4 seal identification
Showing 1 to 10 of 18 results
brokestroke
Send a private message to brokestroke
Hello, I recently bought a 1957 D4 Traxcavator.  Runs great, has a leak that I am trying to track down a seal for.  Parts book wasn't much help.
The seal in question is the one underneath the hydraulic controls in the picture.
 [attachment=75624]20240315_165523.jpg[/attachment]
Sat, Mar 16, 2024 4:00 AM
Thank you received: 59
My guess is out of the hydraulic control, by the picture. That is in a different book than the tractor. But I don't know my Cat hydraulics to tell you what book you need. So you need more help than I can give you, but other should be along soon. So welcome. As all most all knowledge about Cats shows up here, your in the right spot.
Sat, Mar 16, 2024 6:21 AM
Cat Yellow1
Send a private message to Cat Yellow1
Thank you received: 6
Reply to Ray54:
Here is an old thread that may help.
https://www.acmoc.org/bb/discussion-d72/24525-d2-44-hydraulics?start=0
Sat, Mar 16, 2024 6:24 AM
brokestroke
Reply to Cat Yellow1:
[quote="Cat Yellow1 post=255406 userid=8178"]Here is an old thread that may help.
Thanks, looks like a seal that will be pretty easy to find if the D2 and D4 use the same part number.
Here are a couple pictures of the machine.  Had just looked at a smaller Cletrac and then a Massey 2244 when I stumbled upon this.  Motor is pretty fresh, UC is in pretty good shape as well.  I bought it to clear some stumps on some land, it does a great job.  Going to build a ROPS (if you can call it that, operator enclosure) and fix a couple little things here and there.
 [attachment=75627]kimg0721_ca26475754f5b6ac0eb23c41eb896940b60eaf35.jpeg[/attachment]
 [attachment=75628]kimg0724_82ce1b643e3fd7b0e4f083e3bfc9207997193a0f.jpeg[/attachment]
 [/quote]
Sat, Mar 16, 2024 5:14 PM
Thank you received: 54
Reply to brokestroke:
 [/quote]
that seal is available cant tell you the part number though my hydrualics book is for a different model.
you should be able to cross match to a generic seal by taking the old one into any decent bearing or industrial supplier.
Sat, Mar 16, 2024 6:36 PM
willwingo
Thank you received: 8
The No. 44 Hydraulic Control Parts Catalog, form 32856, show the seal as J2382. The original was a double lip seal which are NLA. That is still a good number.
There is room for 2 of that seal on the shaft.
McMaster Carr has Spedi Sleeves that will work on the shaft (1.27" - 1.123" diameter).
You do have to open the case to replace the seal and will need gasket 4F4217.
Sat, Mar 16, 2024 11:38 PM
seiscat
Welcome aboard brokestroke! The ACMOC library has several No 44 hydraulic system parts books that your D4 could have used. Please post your tractors S/N so I know which one to look in for you.
You might want to consider becoming a paying "member" not just a "user." That would give you access to the quarterly ACMOC magazine and the library. The is much to see in the library such as the 32 page D4 sales brochure. Here's a picture of the cover to get you curious.
Craig
 [attachment=75631]IMG_20240223_0001.jpg[/attachment]
Sat, Mar 16, 2024 11:54 PM
bruce oz
Thank you received: 23
 [attachment=75632]cat 44 hyd.JPG[/attachment]
Sun, Mar 17, 2024 1:58 AM
seiscat
Reply to bruce oz:
Thanks Bruce, but I was actually wanting the S/N of the tractor.
Craig
Sun, Mar 17, 2024 2:59 AM
Thank you received: 60
Reply to seiscat:
Craig
Don't let the control shaft drop down or you will bugger up the detent mechanism.
There is a Service Bulletin upgrade.....The single seal has been replaced by the use of two seals.
 [attachment=75635]Control Shaft Seals.JPG[/attachment]
Sun, Mar 17, 2024 4:19 AM
brokestroke
[quote="Old Magnet post=255440 userid=632"]Don't let the control shaft drop down or you will bugger up the detent mechanism.
Any tips to prevent the shaft from dropping down?  Im thinking reassemble the shaft and controls with the pan off so I can watch it closely.
 [/quote]
Fri, Mar 29, 2024 9:32 AM
| Kingaroy, Queensland
