D4 Pony Motor
D4 Pony Motor
TooManyIrons
Send a private message to TooManyIrons
I have a D4-5T that I "saved" and I noticed that the pony motor does not have a governor on it. Also, the pony motor does not seem to be able to maintain RPM when the main engine is set from start to run even at full throttle. The pony starts on the first or second pull and sounds fine.
Were there models of D4 ponys that did not have a governor?
I checked the throttle plate and it is open all the way, so I am wondering why the pony will not maintain RPMs then the main is turning under compression.
Thanks,
C. D. Hunter
Sun, Jun 29, 2008 12:46 AM
Dozerman51
As Far as I know, all D2,D4 and D6 horizontal ponys had governors. You need to get one.
Sun, Jun 29, 2008 1:07 AM
Reply to Dozerman51:
If it starts and runs well, the reason it won't pull the load is probably fuel supply related-
either not enough getting into the bowl or not enough getting through the main jet into the carburetor throat.
Your pony motor should have grenaded itself without a governor and the throttle stuck wide open. When you install the governor, it links directly to the throttle lever with an extended pin and then the control rod goes "behind" the linkage pin extension to pull the throttle closed. The governor spring pulls the throttle open and the weights inside force it closed. The control rod just limits the travel of the throttle/governor arm when you pull it out.
Sun, Jun 29, 2008 3:59 AM
sandman
Send a private message to sandman
ol coyote, I can help you if you need a govenor. Karl [email protected]
Sun, Jun 29, 2008 4:22 AM
