D4 OIL COOLER
D4 OIL COOLER
Paul L.
Send a private message to Paul L.
Have a 1938 4g D4, the oil cooler bolts on the front of the radiator and is seeping a bit. Just wondering if I can remove it and just put plugs in the bottom of the filter housing or do I need to put a loop of line on it ?
Paul
Thu, Feb 29, 2024 10:25 AM
caterpillar13
loop the line back
Thu, Feb 29, 2024 10:48 AM
willwingo
Thank you received: 8
Reply to caterpillar13:
loop the line back
No need to loop a line.
Remove the spring and plug (inside where one line enters).
Use 2 ORFS # 8 plugs.
Thu, Feb 29, 2024 10:46 PM
Thank you received: 54
Reply to willwingo:
you can also do what we did and get a after market trans cooler for a toyota land cruiser and mount that in front of the rad works well. depending on your climate you may be able to put a bypass loop on the lines from the filter body.
Fri, Mar 1, 2024 9:43 AM
