D4 new to me yesterday
Showing 1 to 9 of 9 results
Horsenamedcash
Send a private message to Horsenamedcash
Hi, I picked up this D4 yesterday. I'm posting the serial plate as well if anyone has any info. Got a great deal with a D2 5j  as well.
Mon, Apr 19, 2021 8:35 AM
gemdozer
Thank you received: 25
The D2 5J is 50 gauge.
Mon, Apr 19, 2021 9:03 AM
Horsenamedcash
Reply to gemdozer:
Any idea what the 7J with the W at the end means?
Mon, Apr 19, 2021 9:06 AM
gauntjoh
Librarian
Thank you received: 5
Reply to Horsenamedcash:
Hi,
7J is the tractor serial prefix and the “W” is for wide gauge. Unlike the D2 where a different serial number prefix was used for wide(5J) and narrow (3J) gauge tractors, all D4 tractors had the same range with the W denoting wide gauge.
Mon, Apr 19, 2021 10:21 AM
D4Jim
Reply to gauntjoh:
Hi,
What make of Blade is that? Looks like a pain to get to the pony to start.
Cats Forever
Mon, Apr 19, 2021 12:56 PM
Horsenamedcash
Reply to D4Jim:
The pony has electric start. Yes, it's tight to use the rope for sure. I'm not sure about the blade. It looks really good not like the homemade blades I've seen on D2"s. So I figured it was a factory blade. But that's why I'm looking for advise from the guys who know!!!😁
Mon, Apr 19, 2021 6:55 PM
Thank you received: 62
Many things about this blade looks like Bucyrus Erie, put they used a lot of cast parts. This looks more standard channel and plate welded. Ateco also made similar style blade lift arms, but I have never seen one just like this. Looks like it is able to push some dirt around and not fall apart, as no big repairs showing. But I don't see a hydraulic pump front or back?
Mon, Apr 19, 2021 10:36 PM
Horsenamedcash
Reply to Ray54:
It has what appears to be a factory pump where the pro would be. It works good . I was not sure if blade was factory or if someone did a nice job building it.
Tue, Apr 20, 2021 1:36 AM
nomorejohndeere
Send a private message to nomorejohndeere
I've seen some like it in pics but I don't member the maker
Tue, Apr 20, 2021 6:31 AM
Reply to nomorejohndeere:
Baker Blade?
Tue, Apr 20, 2021 7:07 AM
