D4 Model Number Information Needed
Showing 1 to 10 of 11 results
xzp0hy
Send a private message to xzp0hy
I have become the recipient of a D4. I need information on how to find the model number. I found, cast on the left side of the engine block 6F3787. I am trying to verify if this is the model number. Also, if anyone has information where I can fine the serial number, it would certainly be helpful. I have no operation or maintenance manual so I hope I can fine same. Any help would be appreciated.
Mon, Dec 18, 2006 6:36 AM
Willie
Here you go even if tag is not there scrape away paint it will be stamped in casting where tag was look for 4G,7J,2T,5T,6U or 7U
Mon, Dec 18, 2006 6:43 AM
xzp0hy
Reply to Willie:
Thank you for your reply. I will follow your instructions. By the way, if you have any suggestions on finding a source for operating / maintenance manuals, please let me know.
Mon, Dec 18, 2006 7:11 AM
xzp0hy
Reply to Willie:
Not sure I posted my reply correctly but wanted to be sure you received my reply. Willie, thank you for your reply. I will follow your instructions. By the way, if you have any suggestions on finding a source for operating / maintenance manuals, please let me know.
Mon, Dec 18, 2006 7:21 AM
Willie
Reply to xzp0hy:
First off you need to find out what you have? ser. no.? every seires is diff and in each of those there are many changes, the D4 was most change tractor of any in its run so when you get a book make sure it covers your ser. no. not just the seires. They are always on EBay fairly cheap and easy to find D4 books. There are some on right now.
Mon, Dec 18, 2006 7:29 AM
xzp0hy
Reply to Willie:
Thanks again Willie for your suggestions.
Mon, Dec 18, 2006 8:44 AM
Reply to xzp0hy:
For the D4 you need this one.
Mon, Dec 18, 2006 9:06 AM
xzp0hy
Old Magnet, thanks for the information.
Mon, Dec 18, 2006 9:35 AM
Willie
Reply to xzp0hy:
OM how did you get that to post I have posted it many times on old site but wont work here do I have to resize every pic in my file to get it to work on this BB
Mon, Dec 18, 2006 10:11 AM
bernie
Reply to Willie:
On my D42T there is also a brass tag with identical stamping on the starting engine left side right above the starting pionion lever. It is from when the tractor was taken to the Granite City Engineer Depot for work. They tagged the main and the starting engine identically. My winches cover the rear tractor stamp. Someday I will see what it is.
bernie
Mon, Dec 18, 2006 10:27 AM
Reply to bernie:
bernie
Willie,
For most of the pictures I have I have been able to directly post them here (since JB upsized the allowed file size). This particular one I had to resize to a 750 px width size as it would not fly at 800 px. Other than the quota thing I have not had any other problems but I am no fan of this thumbnail thing.
Mon, Dec 18, 2006 10:38 AM
