D4 main clutch release bearing vibrating
Showing 1 to 7 of 7 results
timothycat
Send a private message to timothycat
Hello,
My neighbor has a old d4 and is having trouble it seems with the main clutch (dry clutch) release bearing. When the clutch is engaged the clutch release bearing and fork shake around like i don't know what. When you disengage the clutch it still shakes around until input shaft stops turning.
We removed the brass/bronze two piece housing around the bearing disc, and the main wear seems to be at the front and back lips of the bronze housing where it runs on the input shaft (not where the disc runs in it). Is this the cause of our problem or what?
At full engine revs, it feels like the clutch leaver is fighting you when you push it forwards to disengage.
Any help would be greatly appreciated,
Thankyou,
Tim
Mon, Nov 11, 2013 4:59 PM
Thank you received: 64
Hi Timothy,
for your lever to be vibrating like that, the throwout flange is likely wobbling. First thing I'd check for is whether the throwout flange is running true. If it isn't, then check whether the whole clutch mechanism is running true - you may have a collapsed pilot bearing (and possibly a shot transmission input bearing).
Neil.
Mon, Nov 11, 2013 9:28 PM
Thank you received: 52
Hi Timothy,
Neil.
I would also be looking in to a worn/misaligned coupling.
Tue, Nov 12, 2013 12:11 AM
Mike Meyer
I agree, I had a similar problem with my D4 7J I recently restored and found the two pieces of the coupling were not aligned properly which made the clutch shake, there must not be any gap between the 2 pieces.
regards
Mike
Tue, Nov 12, 2013 3:36 AM
timothycat
Reply to Mike Meyer:
regards
Mike
[quote="Mike Meyer"]I agree, I had a similar problem with my D4 7J I recently restored and found the two pieces of the coupling were not aligned properly which made the clutch shake, there must not be any gap between the 2 pieces.
regards
Mike[/quote]
There doesn't seem to be any gap between the 2 pieces of the coupling.
I did try (with the clutch disengaged) to lift the input shaft and clutch up , and it did move a little bit (on the spigot bearing end)
With it assembled, the clutch shaft seems to be be running true, but will have to remove the release bearing housing to see if the flange is running true.
If I just engage the clutch to turn very slowly, the clutch fork and outer bearing give a sort of 'kick' back once every revolution.
Thanks for the reply's,
Tim.
Tue, Nov 12, 2013 4:10 AM
STEPHEN
Reply to timothycat:
regards
Mike[/quote]
Tim.
Could the trouble be that one linkage sets from the throwout bearing to the pressure plate is missing, bent , or pins worn out thus creating a off center action of the bearing?
Tue, Nov 12, 2013 7:07 AM
ol Grump
Reply to STEPHEN:
Several years ago I ran into a similar problem with a D4 7U. What I found was the lower bolt going into the trunnion had dropped out. To access that, remove the lower side cover from the flywheel housing as well as the flywheel drain plug. If that's the case, you'll have to get the bolt started and then put an appropriate size socket on it by going thru the side cover. Then poke an extension up through the drain plug hole and into the socket (the socket itself will NOT fit through the drain plug hole so that's why you have to put it in through the side access hole), tighten the bolt and bend the lockwasher onto one flat.
If you have a belly pan, this can turn into a real fun job. Trust me, been there and done that😆
Tue, Nov 12, 2013 8:00 PM
Reply to ol Grump:
Take the coupling apart. The wear will be on the inside.
Tue, Nov 12, 2013 11:55 PM
