D4 Idler
Showing 1 to 7 of 7 results
M00051
Send a private message to M00051
I have a D4 7U28085 and need the parts break down picture w/part numbers of the front track idler. I need to replace the shaft, and two seals that I need the part numbers for and two bushings 7B7166. I would also like any ones input as to where to get these parts new or surplus. This old dozer gets used every year all summer and this year I have three ponds to fix where the muskrats have tunneled through the dike. I used to get parts from Surplus Tractor Parts in Fargo but I see there gone. Any help would be greatly appreciated. Thank You!!
[attachment=34637]D4 Idler Shaft.jpg[/attachment][attachment=34638]D4 Idler Shaft Bushing.jpg[/attachment]
Fri, Apr 1, 2016 12:53 AM
shelbysharpd4
Send a private message to shelbysharpd4
I changed mine over to oil filled like a D4D. Contact White Tractor parts and ask for Warren. The phone number I have is 800-821-2798.
Fri, Apr 1, 2016 6:53 AM
Mike Meyer
Thank you received: 6
Reply to shelbysharpd4:
Easy repair is to weld that shaft and lathe it back to spec though I reckon some of those shafts were designed to be reversed for a extra life, you can also re-sleeve the bronze bushes if you get stuck, but if money is burning a hole in your pocket here are the part numbers from Parts Book 7U27570-Up
Go on the Machinery Trader website and use their Parts Search function, you will find all these parts are available Stateside from different vendors, possibly even your local Cat Dealer
Shaft 3F0641
Seal 7B5638
Bushes 1F2741
Mike
Fri, Apr 1, 2016 10:15 AM
M00051
Reply to Mike Meyer:
Shaft 3F0641
Seal 7B5638
Bushes 1F2741
Mike
Thanks for the phone number shelbysharpd4, sometime I’dlike to switch the idlers to the solid type, my dozer needs new all new tracksbut until then I think I’ll go cheap and try to find a shaft. Mike: I wish Icould use my old shaft but I messed up big time. I have no book and should havegotten one before I attempted to pull the shaft. I tried taking it apart like Idid a D2 and pretty much ruined the shaft (dang). Thank you for the partnumbers, I’m still looking for the shaft.
Sat, Apr 2, 2016 1:08 AM
gemdozer
Shaft 3F0641
Seal 7B5638
Bushes 1F2741
Mike
I have 2 boushing case ass.in very good condition
--------2 new seals 7b5638
--------1 very good idler shaft
Sat, Apr 2, 2016 1:11 AM
ag-mike
Reply to M00051:
These tracks r still 4 sale, i'd like sell both track frames complete. best to call 508 333 933six
[img]http://i113.photobucket.com/albums/n210/wrenchguy49/SAM_2711_zpsnxdzgiwh.jpg[/img]
[img]http://i113.photobucket.com/albums/n210/wrenchguy49/SAM_2701_zpsst2zxh65.jpg[/img]
original post about this machine, http://www.acmoc.org/bb/showthread.php?23794-Parting-out-Videos-F-S-1953-D4-7u-99*-undercarriage-24-quot-shoes-runs-amp-steers&p=151125#post151125
Sat, Apr 2, 2016 1:21 AM
M00051
gemdozer:I will email u, agmike: u have my attention but what's wrong with rest of machine and I think pads are too wide for my blade where it attaches
Sat, Apr 2, 2016 3:22 AM
ag-mike
Reply to M00051:
It don't have a blade. Yes those are 24" shoes, to much griptation for cat engineers to design trunnion mounts for a blade. Probably spin the pinions out of it. good luck.
Sat, Apr 2, 2016 5:18 AM
