D4 hydralic system
D4 hydralic system
Showing 1 to 10 of 12 results
Ttophoven
Send a private message to Ttophoven
What oil is best to use in a late 40's D4 hydralic system? No info in the maintenance manual I have.
Sat, May 8, 2021 6:03 PM
D4Jim
Thank you received: 12
My 40 hydraulic scraper manual says to use crankcase oil. I use John Deere hydraulic / transmission oil in the D4 hydraulics and scraper now. Never had any seal or pump problems.
Cats Forever
Sun, May 9, 2021 5:14 AM
willwingo
Thank you received: 5
Reply to D4Jim:
You don't say what brand/ model of hydraulic system you have, if it is a Caterpillar # 44, form 31677-1, Operations and Maintenance Instructions, says to use "Crankcase Lubricating Oil" in compliance with specifications. Above 10* f, it says use S.A.E. No. 10W.
If you have a 4A or 4S Bulldozer the total capacity is 8 US gallons (44 Hydraulic control is 3 1/2 gallons and the 4A/S system is 4 1/2 US gallons).
Sun, May 9, 2021 5:23 AM
Reply to willwingo:
ISO 32 Hydraulic oil/fluid is my preferred usage.
Mon, May 10, 2021 9:22 AM
Thank you received: 33
you can use the same oil as the engine. or do what i do and use universal tractor and harvester driveline oil. the product i use is caltex textrans tdh it is made for the trans diferential and hydraulics of most tractors and specifically for caseIH/austoft harvesters and infield transporters. it has cat TO4 approvals. and that is the caltex recconmendation delo gold 15w40 or textrans tdh which is also suitable for the transmission.
Tue, May 11, 2021 5:46 PM
Reply to trainzkid88:
I switched to Betty Crocker vegetable oil, if i blow a hose it wont hurt the environment and the used oil is for frying fish.
Wed, May 12, 2021 12:54 AM
D4Jim
[quote="Rome K/G" post=228351"]I switched to Betty Crocker vegetable oil, if i blow a hose it wont hurt the environment and the used oil is for frying fish.
Good one Rome!!
 [/quote]
Cats Forever
Wed, May 12, 2021 4:53 AM
d2gary
Hahaha [img]/media/kunena/emoticons/clap2.gif[/img]
So l guess if you don't follow Cat recommendations you can use whatever you want. I would use the fryer oil that cooked the fish then when you're working you could smell the aroma when everything heated up [img]/media/kunena/emoticons/cool-2.png[/img]
 [/quote]
Wed, May 12, 2021 9:14 AM
Thank you received: 23
Reply to d2gary:
 [/quote]
If you're like the old geezers, you can put your lunch on the manifold at about 11:45 for a nice, toasty hot lunch!
Wed, May 12, 2021 7:18 PM
Elton
Send a private message to Elton
Here in the diesel injection business (non CAT) we still occasionally see someone who uses veggie oil as their fuel. It smells good when burning but isn't good for the fuel system. Used veggie oil is particularly bad because of the salts and unfiltered parts of stuff. We have seen more than one injection pump absolutely trashed for this reason. I expect hydraulic systems could suffer a similar fate, but I don't have any experience with that. Elton
Wed, May 12, 2021 8:01 PM
Reply to Elton:
There's a process to convert straight vegetable oil into biodiesel filtering out the contaminants, but my understanding is that a lot of people can't be bothered so they just run used VO in their engines with predictable results
Thu, May 13, 2021 5:14 AM
