D4 hyd. oil reservoir cap question
JAKEcatHT4
Send a private message to JAKEcatHT4
just recently replace the seals(on my d4/ht4) at the units control levers..While topping off the fluid I noticed that a vent hole was brazed over on the hyd. tank cap. Was this done in past to maybe slow hyd. leaks while the machine was not in use? Should I drill out the weld?
Tue, Jun 8, 2010 9:55 PM
All the #44 pumps and most all Cat hydraulic tanks I have seen use a non vented cap and rely on an air cushion to dampen hydraulic shock.
There is still sort of a mystery about the HT4 though that (going from memory, can't find my manual) shows a vent line tap on that tank mounted above the engine going somewhere???
Tue, Jun 8, 2010 10:22 PM
JAKEcatHT4
okay, OM.... will leave it as is..Started the CAT tonight and put the hydraulics through the motions. No leaks around levers or the cover.. Thanks to you and others including jaker65 for all the good instruction on this task:couch2:
Wed, Jun 9, 2010 8:46 AM
jaker65
Send a private message to jaker65
Reply to JAKEcatHT4:
Your very much welcome! anytime you need help, just throw me a message. Sorry i havent been in touch lately, i have the Ford F250 down with the engine out for rebuild. so i been running around with my head cut off like a chicken, trying to round up parts. Lets see a video some day!👍
Thu, Jun 10, 2010 7:03 AM
