D4 fuel filters?
D4 fuel filters?
Showing 1 to 10 of 14 results
GrantJ
Are there aftermarket fuel and oil filters for the D4 U series? My brother looked at my Cat and said "good, it has the tall filter" but I dont see any reference to more than one style of fuel filter on a 6U. Am I missing something? Grant.
Mon, Nov 12, 2018 3:18 AM
Thank you received: 27
The standard Cat filter system works good, but has gotten rather pricey as you have 3 or 4 sock filters in the tower. They use to box the right number for each application and include the gaskets. But all have gone to one filter per box and no gaskets. But hey are available from Wix and Baldwin and probably others.
I have been buying them at Napa with there big filter sale, close to half price I think it is. Each store seems to do the sale at different time.
Mon, Nov 12, 2018 5:28 AM
GrantJ
Ray, thank you. I had not thought of Napa. I will be at one later this week and will ask. ____Grant.
Tue, Nov 13, 2018 9:59 AM
GrantJ
Went to Napa Auto today and they could find nothing for the U series D4. He did say that if I had Cat numbers, he could probably cross reference. Does anyone have the Napa numbers or the Cat numbers for oil and fuel filters for a D4-6U serial # 6070???. It appears that according to my serial number, I should have the early bypass oil filter but many have been converted to the full flow. I dont know if I can tell without removing the element. Is there any visual way of telling? _____Grant.
Thu, Nov 15, 2018 11:50 AM
Reply to GrantJ:
Fuel filter # is 7B8264 changes to 489-3196 requires four, $14.53 each from Cat. Gaskets are 7B7635 requires two. Bypass filter is smaller with the brass screen housing, the full flow is just the filter element. Full flow filter is 1R0659 from Cat $9.51
Thu, Nov 15, 2018 10:15 PM
Cat 4A0332 changes to 1R0729 $19.77 from Cat. Napa #1165 Wix #51165
Cat 7B8264 changes to 489-3196 Fuel filter = Napa #3825 Wix #33825
Thu, Nov 15, 2018 10:45 PM
GrantJ
Rome K/G thank you very much. With those numbers I can go to my local Napa dealer instead of the 3 hour round trip to the Napa that has a separate truck counter. At the prices you mention, Cat filters are not bad but again, it is the three hour drive. Another cup of coffee and I am off to Napa Auto. Thanks again. Grant.
Thu, Nov 15, 2018 11:23 PM
Reply to GrantJ:
Your welcome Grant! good luck! I always buy a few extra that way you can just grab them off your own shelf and ready to go, same with o-rings, I always have at least a dozen or so of all part numbers used on my equipment on hand so you dont have to run to the dealer every damn time for one o-ring. lol
Fri, Nov 16, 2018 2:27 AM
NAPA number for the full flow filter is 1161, WIX 51161
The bypass filter usually has a T handle on top of the housing while the full flow has a hex nut, sometimes with a slot cut in it for a bar to loosen it.
Fri, Nov 16, 2018 3:47 AM
josh
Thank you received: 8
2A5886 is a four pack of the fuel filters.
https://www.amazon.com/Killer-Filter-Replacement-CATERPILLAR-2A5886/dp/B00AZTZMNQ
Fri, Nov 16, 2018 9:33 AM
GrantJ
I bought the 1161 filter yesterday from Napa for a little less than $15. They had to order the fuel filters (1 day delivery) but the gaskets will take several days. I will find out in an hour or so if the 1161 oil filter is actually what I need. According to the book, my serial # 6070 should have the older sock type oil filter but at this point I am assuming that most old tractors have been converted. If it turns out I need the older type does anyone have a number for that type? I have picked up the Servicemens reference book and operations and maintenance book, but looking at the parts books on ebay, they seem very pricy. I am trying to avoid buying Jensales because of the lousy diagrams, but I may have to. Thanks, Grant.
Fri, Nov 16, 2018 11:21 PM
