D4 Final Drives
D4 Final Drives
R4pat
Send a private message to R4pat
I was wondering if a final drive of a 5T D4 is the same as a 7J D4? will they interchange?
Thanks,
Pat
Wed, Feb 18, 2009 10:40 AM
Thank you received: 19
No, there were major changes to the whole set up when they went from small to large track truck bearing arrangement.
Wed, Feb 18, 2009 11:40 PM
OzDozer
R4Pat - The final drive design of the D4 was changed almost totally in early 1945, at D4 S/N 2T8270. This new design, with an easily distinguished, large outer hub bearing, involved virtually all new parts, as compared to the earlier final drive design as fitted to the D4 9G, 7J and earlier 2T series tractors, up to 2T8269.
The only part I can find common, is the inner spocket taper roller bearing. Here's the two pages from the parts book, you can do your own comparison .. 😊
D4 7J series final drive .. http://img24.imageshack.us/img24/6505/d47jfinaltg2.jpg
D4 late 2T/5T series final drive .. http://img24.imageshack.us/img24/196/d45tfinalhu3.jpg
Thu, Feb 19, 2009 1:46 PM
