D4 final drive filler cap removal or tool suggestions welcome
talley925
Send a private message to talley925
Hey Folks,
Is there a tool for the final drive filler caps? or any creative ways to remove them as one is a large hex shape and the other is a large square shape. One might have been a replacement cap but don't really know why they are different.
Thu, May 30, 2019 10:59 PM
STEPHEN
Drain wrench for sale on the ACMOC store. Fits in the toolbox just right.
Thu, May 30, 2019 11:13 PM
Reply to STEPHEN:
Early plugs were hex type[PIA], the later were 3/4" square, much better. You can use a 3/4" 4" long double nutted bolt also to loosen the hex plugs.
Fri, May 31, 2019 2:30 AM
WA7OPY
Send a private message to WA7OPY
Easy just find a long bolt that the head fits the hex and heat it red hot next to the head and bend it 90d....WA7OPY
Fri, May 31, 2019 7:09 AM
JDcat
Send a private message to JDcat
Reply to WA7OPY:
You can also use a 3/4 in. drive breaker bar for the square plug.
John
Fri, May 31, 2019 10:18 AM
Paso Bob
Reply to JDcat:
John
I use two crescent wrenches. One straight up with the jaws opened to one hex side and the other jaw on the rounded side. Use the other wrench on the first crescent wrench and unscrew it. Works every time.
Fri, May 31, 2019 10:48 AM
seiscat
Reply to Paso Bob:
Yep, the square one is a later-style replacement. You can use a standard ¾" drive tool on that one. Those later-style replacement plugs are available from Caterpillar but are a bit pricey, the last time I asked a few years ago they were $42 ea. I went with this nifty Caterpillar socket part number 212-8146 for @ $30.00. This socket fits the tapered plug properly.
[attachment=54165]DP 2.jpg[/attachment] [attachment=54166]DP 1.jpg[/attachment]
Craig
Sat, Jun 1, 2019 2:36 AM
Thank you received: 257
Reply to seiscat:
Craig
[quote="seiscat"]Yep, the square one is a later-style replacement. You can use a standard ¾" drive tool on that one. Those later-style replacement plugs are available from Caterpillar but are a bit pricey, the last time I asked a few years ago they were $42 ea. I went with this nifty Caterpillar socket part number 212-8146 for @ $30.00. This socket fits the tapered plug properly.
Craig[/quote]
Yup. Much better than a chisel or pipe wrench!
Sat, Jun 1, 2019 4:06 AM
talley925
Craig[/quote]
Thank you, going with the 212-8146
Tue, Jun 4, 2019 12:52 AM
