D4 Different kind of conversion?
Showing 1 to 10 of 12 results
jl628
Send a private message to jl628
Has anyone tried converting the pony motor to a newer design gas motor? Say a Briggs and stratton? I recently repowered a John Deere 400 with a 23 horse Briggs and it works great, easy to start. How hard would it be to rework the gears to drive the main engine? I have never opened it up so I don't know what would be involved.
Thu, Jul 12, 2012 11:53 AM
Thank you received: 40
Hi, Jl628.
I can't answer the technical questions that you have posed but I can tell you that almost anything is possible - - - - - IF you have enough time and cash to throw at it. For mine, there would be two issues here, the engineering side of it and the cost-vs-benefit balance.
Thu, Jul 12, 2012 6:44 PM
ol Grump
Hi, Jl628.
If your pony motor has gone to the great beyond, converting to direct start isn't too hard. .just takes a bit of sweat, skinned knuckles and is probably cheaper than rebuilding the pony. Major expense would be the starter motor itself, an MT 42 or 50. Check Old Magnet's site for the destructions, it'll explain the full procedure.
Thu, Jul 12, 2012 9:22 PM
Thank you received: 23
Reply to ol Grump:
Wouldn't be hard at all - just needs $$ (for new gears, housings, mounts, etc, etc)
Do it and post pictures.
Neil.
Fri, Jul 13, 2012 7:40 AM
dewets
Send a private message to dewets
Neil.
I would rather spend the money and do a conversion to direct electric start. A "happy button" is much easier to operate 😊 than trying to get a "Broke & Stuck" to start... 😞( 😞(
AFAIK B&S designed the horizontal 2 cyl boxer starting engines for Cat, but I may be wrong...
Somerset West, Cape Town
South Africa
Fri, Jul 13, 2012 2:43 PM
dewets
Reply to dewets:
Over here B&S got the nickname (for obvious reasons) of "Broke & Stuck" (Afrikaans version : "Breek & Staan" Breek: Broken, Staan: Stuck, non-operational, stationary (not working)...)
Hence my aversion to a conversion substituting anything to B&S...
South Africa
Fri, Jul 13, 2012 2:47 PM
BillWalter
Reply to dewets:
Like I told another member; When I told the late Fred Hedrick that I was going to paint my 2 TON yellow, he replied; "You can if you want to, but, IT WON'T BE ORIGINAL" I have always been so thankful for such advice from a great historian!!!
You can cobble up a starting engine or a direst electric start; "BUT IT WON'T BE ORIGINAL"
Fri, Jul 13, 2012 10:35 PM
lil cat mec
Send a private message to lil cat mec
Reply to BillWalter:
i agree but then again its all what you have it for... is it for tinkering or work or show or a restoration project??? thats what matters weather its ORIGINAL... lol
1935 CAT 22 2f4455W
CAT 951
Sat, Jul 14, 2012 12:25 AM
jl628
Reply to lil cat mec:
Yeah but I don't have too much concern for it being original. It would be nice but I'm doing this to to work it and make it reliable and functional. One thing I do like about the pony motor is starting in cold weather. It's going to be in central Idaho and used during winter. Not too sure about an electric conversion getting her up and running in 15 degrees.
Can you do an electric conversion and retain a functional pony motor?
Tue, Jul 17, 2012 3:06 PM
lil cat mec
Reply to jl628:
Electric start pony! is that what you mean? or electric start to the main motor and pony to main???
1935 CAT 22 2f4455W
CAT 951
Tue, Jul 17, 2012 3:12 PM
jl628
Electric start conversion and retain a functional pony start to the main. For my needs, I think I'd rather have the pony if I have to pick one or the other.
Tue, Jul 17, 2012 4:43 PM
