d4 crank pulley question?
Showing 1 to 6 of 6 results
Indian4cyl
Send a private message to Indian4cyl
I have a 1940 d47j.I am trying to install a #41 hydrolic unit off a d47u.The crank on the j is threaded for a nut (jaw),the u crank pulley is held with a bolt.Do I need a different pulley?
Wed, Jul 23, 2014 4:21 AM
What model #41 are you trying to mount?
The 24C1-up, 26C1-up, 27C1-up were meant to be front mounted on U models 6U5843-up and 7U11952-up.
The 9V1-up units were meant for the 7J-up models but were rear mounted. I have seen them adapted to front mount but I don't have any info as to how.
Here is the 7J, 2T, 5T drive for the #44 but I am not sure what needs to be done to drive the #41 units.
Wed, Jul 23, 2014 6:58 AM
Indian4cyl
#41 24c2560 off 7u4825 to 7j1990w
Wed, Jul 23, 2014 9:42 PM
Reply to Indian4cyl:
Here is the original application information. Any thing else is going to be an adaption.
Wed, Jul 23, 2014 10:39 PM
Indian4cyl
Thanks for the good info as always.I am off now to pick up a tool bar sub-soiler that was included in the 7u.I know nothing about tool-bar stuff or that it is even made by cat.
Wed, Jul 23, 2014 10:54 PM
Thank you received: 23
Couple of questions:
- Indian - what's the per-axle rating on your trailer? How did you find the stopping power (all electric?)
- OM - what advantages could be gained from having the pump on the rear other than avoiding some piping? Can't think of a good reason to have it rear-mounted, and the disadvantage of not having it live drive would annoy the jingle out of me. I was rapt when as a kid I first discovered live PTOs....my mother had a TEA Fergie and that was the one thing that bugged me about that tractor. (I'm sure there must be a good reason but I can't think of one - limited imagination I suppose)
Wed, Jul 23, 2014 11:25 PM
I can't see where there is/was any advantage. Just a product of the times when hydraulics were mostly for opening and closing a disc. Same goes for the very popular BeGe units of the time.
Interesting that the 9V1-up units were the only Cat hydraulic control to use a gear pump, the rest being vane pumps that have built in sensitivity to cold load starts.
Wed, Jul 23, 2014 11:41 PM
