D4 clutch
D4 clutch
yohan
Send a private message to yohan
If a D4 quits pulling when one of the steering levers is pulled would that mean the steering clutches are shot on one side? How much are clutch discs?
Thanks for any information.
Wed, Jul 4, 2007 10:26 AM
Could be, if all the adjustment is used up.
Discs are available from: www.steeringclutch.com
Thu, Jul 5, 2007 8:12 AM
yohan
Thank You I appreciate it.
Thu, Jul 5, 2007 8:31 AM
yohan
Reply to yohan:
Okay, Got the chance to look again at this tractor. Took off the covers and found that the brake band and all other surfaces have oil all over them.
My guess is there is a seal leaking. My question is can the clutch disks and brake band be cleaned with something while changing the seal and used again or are they scrap because they are oil impregnated?
Mon, Jul 16, 2007 1:27 AM
gemdozer
Thank you received: 12
Reply to yohan:
you can réused these disc after cleaning with gas or varsol.
Mon, Jul 16, 2007 1:53 AM
