D4 Cat 7U17640 1952
D4 Cat 7U17640 1952
Showing 1 to 10 of 10 results
Hayhauler44!!
Send a private message to Hayhauler44!!
Looking to replace pony motor with electric start. Any information would be very helpful on how to get a kit to do this.
Fri, Jan 15, 2021 11:57 PM
nomorejohndeere
Send a private message to nomorejohndeere
https://sites.google.com/site/oldmagcat/home/cat-d2-starters-conversions
Sat, Jan 16, 2021 12:33 AM
Hayhauler44!!
Reply to nomorejohndeere:
Thanks, appreciate the information.
Sat, Jan 16, 2021 12:57 AM
Hayhauler44!!
Reply to Hayhauler44!!:
This cat doesn’t have the bell housing your referring to. Can you mount the starter where you engage the pony motor to the fly wheel?
Sun, Jan 17, 2021 12:08 AM
nomorejohndeere
You have to drill a hole for the starter in the bellhousing with a hole saw and drill and tap mounting bolt holes. Does your bellhousing not have the machined blank for that?
There have been people mount there own homemade starter engines in place of the pony. Good luck.
Are you going 12v or 24?
Are you in a cold climate?.
If you are you will want a way to warm the engine before using the electric start as your engine does not have glow plugs.
Or add glow plugs.
Some people attach a belt around the pull start pony flywheel and power it with another engine or electric motor. Using the tractors original pony clutch and pinion engagement system.
Or pull start or park at top of a hill.........
Sun, Jan 17, 2021 6:12 PM
Hayhauler44!!
Or add glow plugs.
Thanks, it looks like we will take your suggestions and park on a hill or pull it for now.
Mon, Jan 18, 2021 3:38 AM
nomorejohndeere
I'm sure I've seen people attach a starter to the pony drive engagement pinion. I think there is a company that makes one.
It's been awhile since I looked at all those possibilities.
Does your machine have a PTO?
Mon, Jan 18, 2021 10:40 PM
Hayhauler44!!
It has a winch on the back. It’s old but fairly good shape, don’t want to put a lot of money in it. Might just pull to start. Thanks for your help.
Tue, Jan 19, 2021 5:10 AM
Hayhauler44!!
What were your thoughts on the rear pto
Tue, Jan 19, 2021 5:11 AM
nomorejohndeere
turn the pto with a tractor to start
roll start works fine just don't run outta fuel or stall in a spot you can't pull out of
I guess you could engage the winch and pull start it like a big lawn mower............
fix pony
Tue, Jan 19, 2021 8:52 AM
Thank you received: 32
fix pony
It's simple to drill the holes necessary to fit an electric starter. Unless someone's made some strange swap, your bell housing does have the boss that you can drill. You can do it with a hand-held electric drill and a hole saw from the hardware store. You might have to rest once or twice / take a break but it's not that hard to drill the big hole. Main critical factor is to ensure your holes are centered fairly accurately (e.g. within 1/😎 but even so, if you're out, you can file and wiggle some. Electric starter components are all available from various sources.
Tue, Jan 19, 2021 9:36 PM
