D4 block heater
D4 block heater
Showing 1 to 9 of 9 results
cowboyofequipment
Send a private message to cowboyofequipment
Help Needed??? Is there a block heater for a D4 7U? If so, where should I look? Any and all help is appreciated. 😕
Mon, Nov 10, 2008 9:54 AM
Thank you received: 39
Most of em used an external circulating type.
Try Googling the "Watlow" brand......if I got the name right😊
Mon, Nov 10, 2008 10:31 AM
D4Jim
Thank you received: 16
Cowboy, MB. Cat hooks up the heaters as shown in the two photos linked below. I plan on doing the same to my D47U when I can get to it.
Looks like a pretty easy installation except for drilling and tapping the head of the pony 1/2" NPT. The other end attaches to the lower radiator supply at the tapped hole that is already there.
These are John's (MB. Cat) photos.
http://img217.imageshack.us/my.php?image=d2heater01wn5.jpg
http://img217.imageshack.us/my.php?image=d2heater02yp7.jpg
I have several Kats that seem to work OK.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200339137_200339137
Cats Forever
Mon, Nov 10, 2008 1:37 PM
Reply to D4Jim:
On the "U" models it's more common to run a circulation circuit from the flange on the side of the thermostat housing to the pipe plug fitting on the lower radiator pipe.....no taping required.
Tue, Nov 11, 2008 12:03 AM
D4Jim
OM, That looks like it would be even simpler. I was wondering if that would work. Looks like all one would have to do is drill a hole in the flange cover plate and weld a coupling to the plate or even a short nipple for that matter.
Cats Forever
Tue, Nov 11, 2008 1:09 AM
D4Doug
Send a private message to D4Doug
Reply to D4Jim:
On my 7U I ran a hose from the plug on the lower radiator hose to the drain vent on the top of the starting engine. The water circulates nicely through both engines.
Tue, Nov 11, 2008 2:24 AM
Reply to D4Doug:
That will work to.....but be sure to check either approach to see that the pony cylinder area is getting heat and not plugged up with the usual sediment😊 😊
Tue, Nov 11, 2008 8:24 AM
cowboyofequipment
Thanks for the info. I would like to find an element to screw into the lower pipe. Dont know if anyone makes one.I have two of the tank type on other equipment.
Tue, Nov 11, 2008 9:33 AM
ol Grump
Reply to cowboyofequipment:
The last 7U that I bought has an inline heater plumbed from the lower pipe to the left side of the block, right behind the governor.
Tue, Nov 11, 2008 10:34 PM
bcwayne
Reply to ol Grump:
Today I installed a " Kat " brand heater on my D2... will attach to the engine side panel with a U-bolt. I ran the heater long enough to insure that it worked, but not long enough to really warm the engines.
Because I'm adding direct electric start for the diesel engine, and don't have glow plugs, I thought it would help with the first startup of the day.
Fri, Nov 14, 2008 4:04 AM
