D4 at Auction
D4 at Auction
Showing 1 to 10 of 14 results
npalen
Send a private message to npalen
This unit is up for auction locally and curious about what year it is.  I can't quite make out the prefix on the SN plate but I want to say its a 4U4866.  Would the 4U be correct?  The tractor shows 33XX hours and I believe its the wide gauge.
Mon, May 9, 2022 5:06 AM
Thats a 7U series, looks like late 40's to early 50's. Five roller track frames, Dakota blade.
Mon, May 9, 2022 6:53 AM
npalen
Does that look like original undercarriage based on 33XX hours?
Mon, May 9, 2022 8:35 AM
Reply to npalen:
I would say yes, original shoes, lock washers with the track bolts, good rail height and good sprockets. But might have been replaced many years ago.
Mon, May 9, 2022 8:39 AM
Does it have an equalizer spring or a rigid cross frame under the engine? With that side air cleaner, it may have been set up for a pipelayer, Trackson PD4
Mon, May 9, 2022 8:44 AM
npalen
Reply to npalen:
Good question, I will have to look. What applications would each be used in? (spring vs rigid)
Mon, May 9, 2022 10:44 AM
GrantJ
Thank you received: 10
Reply to npalen:
Does that high fuel tower make it look like earlier than a U-series? I thought that the G-series had the tall tower and the U-series tower was lower. It may just be my bad memory.
Grant.
Mon, May 9, 2022 11:25 AM
Thank you received: 140
Reply to GrantJ:
Grant.
Hi, npalen.
The rigid cross members were used on sidebooms and track loaders. Bare tractors and dozers used the equalizer spring to allow oscillation of the track frames.
Mon, May 9, 2022 11:57 AM
npalen
Hi, npalen.
https://hansenonlineauction.hibid.com/catalog/367271/2-day-spring-farm-machinery-consignment-sale/?q=912&m=1&ipp=10
This links to the auction which is today. I noticed two sets of hydraulic quick couplers on the back which are apparently controlled by the two handles on the right of the seat.
A third valve handle is probably for the dozer. The quick couplers would seem to be for a drawn implement but I see little to no wear on the drawbar pin hole.
Mon, May 9, 2022 8:03 PM
Reply to npalen:
I zoomed in on the pics and you could see it's a rigid frame, it was probably ordered for a track loader to be put on it but somebody decided to just put a blade on it. It has the heavy frames on the inside of the idlers for a loader frame also.
Mon, May 9, 2022 10:22 PM
TooManyIrons
Send a private message to TooManyIrons
Based on what I can make out from the pics the engine looks like a D4400. It could be a 5T series D4 if that is the original engine
Like that blade setup!
Tue, May 10, 2022 1:59 AM
