D4 7U33999 possible new owner questions
gunnarrenner
Send a private message to gunnarrenner
I am looking at a D4 track loader my friend's family is selling. (he is letting me figure out what is wrong before i commit) It was from the local township and has sat around their farm for 10-12 years with some use. From reading a bunch your posts the undercarriage is worn but has enough life to last me some time. I was assured the cat supposedly only has 3800hrs, clutches, Brakes, engine, loader, electric start(conv.) all work. The problem is with the engine, there is exhaust getting into the cooling sys. from reading posts I gather this is most likely from a bad liner or a pre-comb. chamber. The head gasket was recently replaced due to a compression leak to the outside of the head. My question is whether it is likely to be the the liner because of previous problem or if this is improbable due to low hrs and hopefully the PC Chamber.
I have ordered the chamber removal tools form M.B.S. but if i could get a link to the best 7U PC chamber removal instructions with maybe a diagram it would be great. I am planning on doing a pressure test to isolate the faulty cylinder. also any recommendations on where to get the best value replacement parts would helpful.
Thanks for the help, i only have antique tractors on rubber and only on diesel which fortunately has not needed serious service yet.
D4 7u track loader
deutz 6806
JD 50
JD A
farmall H
towmotor 4000#
Fri, Apr 2, 2010 7:07 AM
Hi...almost a Cat owner,
The first thing that comes to mind is when an engine starts having water leak problems the owner generally abandons or minimizes the use of antifreeze and corrosion inhibitors so corrosion and sediments in the water side accelerates making liners and pre-combs likely candidates for leakage.
I'd recommend you get yourself a set of manuals or find access to review the material that pertains to your symptoms.
Parts sources are pretty well described in the "sticky" at the top of the discussion page.
If you can't sort it out with the info at hand or by searching the topic, come on back and we will assist you. Good luck and welcome😊
Fri, Apr 2, 2010 10:29 AM
gunnarrenner
thanks for the help i hope the machine works out, i would love to save it from the scrap man.
D4 7u track loader
deutz 6806
JD 50
JD A
farmall H
towmotor 4000#
Fri, Apr 2, 2010 5:47 PM
SJ
Send a private message to SJ
Reply to gunnarrenner:
At the dealer I made up a pressure testing tool to check cylinders for leakage and other problems. I got a retaining nut that holds the nozzles and stem down in the chamber and welded a pipe nipple on it so I could attach an air hose on it and I also had a pressure regulator in the air line and would set the pressure at about 90 lbs. and would put the engine on TDC on the cyl. I was checking and then observe if air was getting in the cooling system or any other symptoms showing up.I used this dozens of times at the dealer and told me so much when looking for a problem.Cat later came out with a dummy nozzle with a straight through hole in it to do he same test but the one I made worked good.If the engine tends to turn when you put the air down on the piston you can put the tractor in gear with the clutch engaged and the brakes on but make sure the throttle is in the off position.Remember the cyl. your checking has to be on TDC on the firing stroke so the valves are closed.Forgot to mention, that it,s good idea to put a shut off valve in the line before the pressure regulator and you can turn the air off once you get the pressure built up in the cyl. and then you can observe leak down on the cyl. and how fast it is escaping. This test will and can pin point where or what the problem is causing it.This testing saved so much time finding out where a problem was in an engine at the dealer and saved the customer money too.
Fri, Apr 2, 2010 7:10 PM
gunnarrenner
Reply to SJ:
that sounds like a great idea, do you know what size/pitch threads are on the injector nut. as i have to go to my buddys shop to work on the machine i would like to make a tester up before i go over there.
thanks a million
D4 7u track loader
deutz 6806
JD 50
JD A
farmall H
towmotor 4000#
Sat, Apr 3, 2010 4:06 AM
8C 361
thanks a million
I have used the rubber tip off of an automotive compression test gauge. The one I used slipped over a 1/4" pipe. It fit right in where the injection capsule goes and you can easily hold it against 100 psi air pressure. I have seen a couple of kits in Wally World air tool dept that you could make one up for 20 or 30 bucks.
Tom
Sat, Apr 3, 2010 4:19 AM
SJ
Reply to 8C 361:
Tom
If you go the route of making up an adapter just take the nut to someone that has a thread gauge if you don,t have one and get the diameter of the nut so you can get material to make one up.
Sat, Apr 3, 2010 5:13 AM
cr
Send a private message to cr
Reply to SJ:
Here is a tool I made out of 6061 T6 Al.
Sat, Apr 3, 2010 10:51 AM
gunnarrenner
Reply to cr:
wow, that's classy, the one i make won't look that good. BTY the thread size on mine is 1"-14 (1" fine thread)
D4 7u track loader
deutz 6806
JD 50
JD A
farmall H
towmotor 4000#
Mon, Apr 5, 2010 9:46 AM
