D4 7U18212 Clutch Wear
1S1K
Send a private message to 1S1K
Can somebody tell me the new and worn limit thickness for a D47U dry clutch, has some specs in repair manual but nothing about disc thickness. Thanks.
Tue, Feb 18, 2014 7:21 AM
New disc thickness is 17.5mm. Don't know of a spec for minimum thickness. Usually replace when groove pattern is about gone.
That's for a 5F7048 disc.
Tue, Feb 18, 2014 10:18 AM
1S1K
Thanks, Where did you find that spec? It would be nice to be able to look stuff like that up myself. I will check my disc tomorrow and see what it is at, I only have about 2 turns of adjustment left before the adjuster will bottom out. I lock it by hand on the bench and tighten as tight as I can by hand until the disc won't move, then I unlocked and it has about 2.25 turns left until it bottoms out, it seems like that is not much left before the disc would be totally worn out and slip all the time. Any thoughts?
Tue, Feb 18, 2014 11:28 AM
Reply to 1S1K:
It's not all clutch plate wear. Part of it is due to linkage wear which changes the leverage and fulcrum points. The adjustment is to compensate but there are limits to the range.
Tue, Feb 18, 2014 2:31 PM
