D4 7U with Frozen chains
EMD645
Send a private message to EMD645
I was looking at a D4 (7U41112) from a guy just down the road from me in NE, only issue is the thing hasn't run in 8 years and it doesnt roll. Chain, Rollers and Idlers look nearly new? My questions are #1 should I just run?, #2 If I can get the Diesel running can I use it to break the chains loose? #3 if I can't or shouldnt use the engine running how should I attempt to break the chains loose? I found lots of great posts about soaking them in water, the only issue is I would have to get it to a place I could take the tracks off to do that which would require two seperate lifting jobs. Asking price is $2K seems pretty high for the condition. Any and all thoughts welcome.
Sat, Sep 21, 2013 12:27 PM
ol Grump
The first thing to do would be to take the drain plugs out of the finals to make sure there's no water in 'em. If there is, there's a good possibility the brake bands may have rusted to the brake drums. No water? Back off the band adjusters and brake band support adjusters a few turns to make sure there's clearance between the bands and drums.
if you have a high lift jack, you can set it up and use it to lift up on one of the pad cleats half way up at the sprockets and do this on both tracks. If it moves a bit, a chain to the top of a track and the other end to a sturdy 4wd pickup or tractor should get it moving.
Once it moves, then it's time to try to fire it up but I wouldn't try it unless I knew it was movable. Remember, you've loosened the brakes so they may not work and above all, BE CAREFUL!!
Sat, Sep 21, 2013 7:16 PM
EMD645
Reply to ol Grump:
Brakes, main clutch, and both steering clutches feel really free and actually quite close to proper adjustment. All oil levels are good and moderately clean. How would you suggest going about that maneuver with out a high boy jack? Will a tall bottle jack work? Or too much force?
Sat, Sep 21, 2013 7:48 PM
josh
Thank you received: 13
Reply to EMD645:
I would try to get the tractor running, if you do get it running the best way is to gently start rocking it back and forth in first and reverse, that will put much more force on the chains than you can do with trying to pull or push the tractor. All around having the motor running, and clutch working will make working on the machine much easier no mater what you have to do to free up the chains.
You don't have to submerge the tracks, although that would be best to run it in water that is deep enough to cover the tracks, say six inches or so, just spraying them down with whatever water you can haul to the cat will help.
Sun, Sep 22, 2013 12:31 AM
Thank you received: 50
Reply to josh:
It is amazing how much a brake band rusted to a drum will hold.Had a D6 that another D6 would not move from the brake rusting together.Was going to check in clutch compartment so removed fuel tank backed brake off and taped it lose. A little wheel tractor then moved it to where I wished to work on it to remove clutches. Back brake ajustment up and tap on lining before doing harder things.
Ray
Sun, Sep 22, 2013 5:40 AM
