D4 7U Water Pump part #
Showing 1 to 9 of 9 results
dandawn79
Send a private message to dandawn79
My D4 water pump is leaking really bad. I need a new seal kit or a pump. its a 1952 D47U serial number 7U16108SFG I dont have a parts manual. Also were can I get these parts? Does anyone know what the SFG means on the back of the serial# ? Thanks again Dan
Fri, Sep 6, 2013 11:00 PM
gemdozer
dandawn79
Reply to gemdozer:
The front seal should be 7b2174 and the rear one 4f4769
I have a parts manual coming but it wont be here till after i go work on the Dozer. Is there a part number for a complete pump or rebuild kit? Thanks Dan
Sun, Sep 8, 2013 12:48 AM
gemdozer
Reply to dandawn79:
The water pump housing is 4f7963
Sun, Sep 8, 2013 2:18 AM
dandawn79
Reply to gemdozer:
Ok I called western states cat here in spokane area.They want 400.00 dollars for it.were can i get a pump or a rebuild kit?This shouldnt be this hard.I can rebuild it at work Does this just need those two seals to make it work? The bearings feel tight but until I get it apart I cant really tell. Thanks Dan
Sun, Sep 8, 2013 4:15 AM
Thank you received: 52
Reply to dandawn79:
Here is the parts break down for the water pump on a 7U16108 s/n.
Check with Cat to see if they have a kit, otherwise it's find individual parts or purchase used. For used I'd try www.tractorparts.com
Sun, Sep 8, 2013 5:42 AM
dandawn79
Thats exactly what i was looking for.thanks old magnet i have a book coming but it wont be here for a bit so ill get these parts coming monday.
Sun, Sep 8, 2013 2:27 PM
Reply to dandawn79:
Does anyone have the number
Mon, Feb 12, 2024 7:51 AM
Floyd Green
Send a private message to Floyd Green
I just GOOGLED "CATERPILLAR 7B2174 SEAL" and found them at $1.50 TO $14.00 and the 4F4769 listed at $15.00
Mon, Feb 12, 2024 11:46 AM
