D4 7U Track Sprocket
Showing 1 to 10 of 12 results
M00051
Send a private message to M00051
I have a D4 7U28085 tracks are shot my pads are ok. I purchased a scrap Cat for decent chain, front idlers and lower rollers. What is the easiest way to repair rear sprockets? Is there a way to weld new tooth assemblies on without removing the track frame?
Fri, Feb 24, 2023 5:12 AM
Thank you received: 63
We did exactly that. We cut about a 60 degree sector out of a new sprocket ring, and welded it onto the spokes without having to remove the track frames or sprocket. This was on an HT-4 which is not great for removing track frames. Did it just this past summer to both sprockets. Couldn't be happier with it
Fri, Feb 24, 2023 6:11 AM
hfdzl
Also try here if you want. He makes inserts for the sprocket teeth. https://www.manta.com/c/mmdjxfq/pigeon-products-mfg.
Does a good job, lots welding. If you are handy you can make your own liner inserts.
Good luck
Fri, Feb 24, 2023 6:59 PM
Reply to hfdzl:
Good luck
I dont like welding near bearings or close to an engine, I have seen [not my machines] where bearings were "arc'ed" or pitted from welding on the machine.
Sat, Feb 25, 2023 9:54 AM
hfdzl
You have to be careful to welder ground placement.
Sat, Feb 25, 2023 10:43 AM
Thank you received: 52
Reply to hfdzl:
place the work lead close to the weld and have a spot ground nice and clean for it to get a good contact. it can be a good idea to shift it for each weld many bad welds can happen due to poor prep and crook earth clamps the best are one that are a proper clamp and not just relying on spring pressure. remember electric current will always flow to terra firma by the path of least resistance.
Sat, Feb 25, 2023 6:12 PM
Reply to trainzkid88:
when i welded my new sprocket rims on I moved the ground lead to each spoke as i welded the rim to that spoke
Sat, Feb 25, 2023 10:16 PM
restore49
Not sure proper name - Beam Clamps with a bolted on ground wire and ground clean clamp area work great and easy to move to new spot.
Mon, Feb 27, 2023 8:54 PM
M00051
dpendzic, What did you mean by welding sprocket rims on? Is that a part I can purchase if I do remove the track frames? I guess I think I'm looking for the best solution, I just thought maybe there was a ring with bolt holes available to cut old sprocket tooth ring off, weld ring with bolt holes on old sprocket and then bolt tooth sections on? I must be dreaming right! Vic
Wed, Mar 1, 2023 6:31 AM
Reply to M00051:
Both Berco and Cat had new sprocket rims==I went with Cat as they were a little cheaper---I don't know if rings with holes are available for these old machines---newer machines have a sprocket with holes to bolt on sections of teeth---as Neil said you can cut a section out of a new rim and slide the rim on and then weld the section back in---the other alternatives is build up the teeth with weld or weld inserts in the old teeth
Wed, Mar 1, 2023 8:12 AM
Reply to dpendzic:
Having done it the way we did, and knowing how long it took (half a day each with the welder taking his time and checking everything 3 times), I'd do it that way again. Not to say that the cups isn't a good alternative but I do like the idea of all new-teeth with the expected hardening etc.
Thu, Mar 2, 2023 1:38 AM
