D4 7U track adjustment.
Showing 1 to 10 of 23 results
bplunk
Send a private message to bplunk
I have the manual adjusters on this 7U and the tracks need tightened and the 4 inch max has been reached on the adjusting screw. A link needs to be taken out of the chain and then readjusted. My question is: is there some kind of a"fix" that could be done other that the link removal that would let me tighten the track some so I could use it? There is room for the track to slide forward on the frame, about 5-6 inches. I only use this unit about 20-30 hrs. a year. I am worried about throwing a track with the tracks being so loose. Any advise or suggestions would be appreciated.
Thank you.
Fri, Aug 31, 2018 8:35 PM
d2gary
Thank you received: 49
I have a d4 5t that has tracks way passed 100% wear.
My "fix" was to have grade 8 threaded rod made to replace the adjustment bolt that goes through the spring. I pulled the idlers all the way out and got a measurement for the extra length. The spring and bolt will come out without splitting the track. I used the neighbors 30 ton press and compressed the spring installed the longer bolt and have been usi g it that way for almost a year with no problems
There is a thread on the BB on what I did, D4 going in the shop. Sorry don't know how to post a link.
Fri, Aug 31, 2018 10:19 PM
daron
Reply to d2gary:
http://www.acmoc.org/bb/showthread.php?27155-D4-going-in-the-shop
Sat, Sep 1, 2018 3:21 AM
nomorejohndeere
Send a private message to nomorejohndeere
If your thread and nut still work you could extend the length
meaning cut/weld in a spacer
Sat, Sep 1, 2018 4:10 AM
Glum
Reply to nomorejohndeere:
The most common trick was to add spacers between the idler and the yokes, with longer bolts to attach the idler.
Have also seen spacers under the carrier roller to take up a little extra slack.
Sat, Sep 1, 2018 11:08 AM
catsilver
Reply to Glum:
Spacers in the idle yokes are much easier and SAFER option than putting a different bolt through the spring.
Sat, Sep 1, 2018 4:09 PM
bplunk
Reply to catsilver:
I like Catsilvers suggestion of spacers in the idler yokes best. I have been a Cat operator but not a Cat mechanic so please bear with me if I ask really dumb questions about the mechanic side of how to fix something. 80 years old, retired and like to run the old D4 but short on mechanic ability.
Could you give me a "walk thru" on the procedure to get the spacers on the yoke? Also what do you suggest I use for spacers? I will probably need to heat the adj. nut and the clamp nuts to loosen. I have a torch for that.
Thank you.
Sat, Sep 1, 2018 5:57 PM
8C 361
Thank you received: 11
Reply to bplunk:
Thank you.
Removing a link is not really a good thing to do. When wear reaches that point the elongated pitch is going to chew your sprockets anyway. Spacers on the yoke is the best answer. Even a stack of washers and longer bolts will work.
Sat, Sep 1, 2018 6:48 PM
Machias cat
Send a private message to Machias cat
Reply to 8C 361:
[attachment=50525]20180901_081527.jpg[/attachment]
Bplunk,
Here is an example of a spacer installed on a D2 idler yoke. D4 would be similar.
If I was doing the repair, I would first back off the track adjuster a fair bit so that when I installed the spacer (made as thick as possible), I would then have the ability to tighten the track some more later on.
As you can see by the picture, this isn't high tech engineering involved here; just use some plate stock of the thickness you need, get the hole pattern right and change out the bolts to longer grip length. Obviously you will have to do this repair to the inboard and outboard idler yoke arms.
Your biggest hurdle may be getting the bolts free to take the assembly apart. A little heat should make it come apart.
Sat, Sep 1, 2018 10:32 PM
Thank you received: 44
Reply to Machias cat:
Bplunk,
Cat offered the spacers and they're still around....
https://www.machinerytrader.com/parts/construction-equipment/search?partnum=4B8649&pst=starts
Sat, Sep 1, 2018 11:18 PM
bplunk
Bplunk,
Ok. First i want to say thank you to everyone that's given suggestions for my track tightening project.
Here is the plan. The shields are off. No spacers have been used on the yoke, its original. I will first remove the 4 cap screws that hold the yoke. Then loosen the two track adjusting nut clamp nuts. then back the large track adjusting nut off about 2'' or more depending on how hard it turns.. This nut is slotted on three flats clear into the threads on the adjusting bolt. That should make it turn easier once it is broke loose. I will then get the spacer made, put in with new longer bolts and tighter the track. Does that sound right?
I have company for the Labor Day weekend so I will be entertaining them and wont get back to the D4 until Tuesday something. Thanks again for your valued info that you share... bplunk.
Sat, Sep 1, 2018 11:38 PM
