D4 7U Steering Clutch Pack thickness
Glum
Does anyone have a new and worn spec on the overall width of the steering clutch packs for the later model D4 7U's (effective from 7U26503) ? These clutches have 11 3F5504 and 11 2H6936 discs per clutch assembly.
I have a spec on the earlier type which uses 8 friction and 8 steel discs but there are number of differences between these and the later ones so I'm not sure the same spec applies.
Wed, May 4, 2016 8:33 PM
According to www.steeringclutch.com spec sheet the D4 series is all the same until you get to the 40A.
http://www.tractorparts.com/spec_sheet.htm
Wed, May 4, 2016 10:56 PM
Glum
Thanks for the link, Pete. I had seen their site but not the specs page.
Thu, May 5, 2016 11:45 AM
Glum
Reply to Glum:
A little more digging shows my tractor uses 3F-5504 Disc (22 off) and 2H-6936 Disc (20 off)
Info out of some early D4D books shows the same P/N's and quantity of discs with the following info on pack thickness:
Total thickness-new plates and discs ... 70,79-78,54 mm 2.787-3.092 in.
Minimum permissible thickness-worn plates and discs ... 66,80 mm 2.63 in
Just thought I should follow up on this in case its of any use to someone else.
Fri, May 6, 2016 2:27 PM
