D4 7U Starting motor
Showing 1 to 6 of 6 results
wimmera farmer
Thank you received: 10
Looks like I will be needing a head gasket for a starting engine. Opened drain cock and quite a bit of coolant came out. Has been suspect for quite a while.
Is 6F4201 still a good number for a head gasket. thanks WF
Sun, May 31, 2026 10:02 AM
gemdozer
Thank you received: 25
You could check in same the head and block hole coolant circulation could be pluged or crak head
Sun, May 31, 2026 2:51 PM
Thank you received: 78
Hi WF, I have 488-8155 as an alternative (I think - it's in the right column in my spreadsheet as the successor to 6F4201)
Sun, May 31, 2026 2:55 PM
Thank you received: 95
Hi WF,
maybe Chapter 19 could have some.
Mon, Jun 1, 2026 3:00 AM
Breadler
D2/D4 Pony motor head gaskets are still available from Caterpillar. I purchased a set last year.
D5C, D4-7U, D2-5U, D2-5J
Mon, Jun 1, 2026 10:01 PM
wimmera farmer
Thanks for updated number will get busy. Chapter 19 don't list these as still available from Cat.
Mon, Jun 1, 2026 10:50 PM
ChrisE
Thank you received: 41
Hi WF. Those gaskets are normally copper. If there is no obvious damage to it they can be anealled by heating then quenching. Might be worth a try. The water ports at the bottom are normally blocked aswell. Good luck, keep us posted on what you find.
Wed, Jun 3, 2026 12:38 PM
