D4 7U Precup
D4 7U Precup
Mike Walsh
Question for OM. I remember reading a previous thread where you pointed out that the D47U head changed from part no. 5F1291 to 1H7657 around serial no. 7U19771 and I think you said the later head would accept the larger 1S-1970 precup which is bored for a glow plug. I was pretty happy about that until I started reading my parts book and got myself confused. My parts book shows the same precup (4F8517) for both heads. I bought another parts book covering serial no-s 7U27570 - end, thinking maybe the head changed around 29K rather than 19K, allowing for the larger precup. Parts book says the 1H7657 head was used on all tractors mfg between 7U27570 to end and that the same precup (4F8517) was used in the later tractors as well. What am I missing. Is my book wrong. Have aluminum pots irreversibly affected my ability to reason. How can the 4F8517 precup fit both heads with different size holes. I remember measuring a 2S-1273 precup (updated no.) which fits the earlier head and determining it was a smaller diameter than the 1S-1970. Is there another head used on direct electric start engines that I missed somewhere else in the parts book?
Fri, Jan 29, 2010 5:43 AM
Note the change in the pre-com chamber retainer. This allowed using the standard pre-com in the larger hole head but with the retainer removed you have the correct diameter for the one piece glow plug chamber.
Also recently verified that the earlier heads can be bored out for the larger pre-coms
Fri, Jan 29, 2010 6:35 AM
Mike Walsh
Thanks for the info. Previous reply failed to post.
I did not know there was a precup retainer. Never worked on anything above 17K. Now I can take another look at a parts machine with a replacement head. At first I thought it had a 1H head but after measuring the top of one of its precups concluded it was a 5F. Hope I was wrong. Couldn't find a casting number and concluded it was behind the water pump.
There was a machine shop in Watsonville or Freedom whose owner was reputed to be an expert when it came to boring heads for the larger precups. Its been a few years and I do not remember his name. He was young enough to still be in business. From what I remember he worked on a lot of coastal crawlers.
I have a friend who has turned dozens of 1S-1970 precups to fit the 5F heads. The oring groove gets similar treatment. He resorted to this to decrease the cost of conversion to electric start and has never had a failure. I would have thought the precup would get a little thin between the glow plug and the oring but maybe all the pressure and force is down below and the top of the chamber does no more than serve to center and seal the precup in the head.
Thanks for the help.
Fri, Jan 29, 2010 4:29 PM
Reply to Mike Walsh:
All of them have a retainer (Cat part name)....probably not the best name as they don't retain the pre-com but do retain the water😉
Seems like you are referring to Moreno's Machine Shop. Les Moreno (spelling might be off) was the go to guy for all the old iron in the valley but sadly, Les has been retired for a long time.....not even sure he is still alive....and the kids and clan have taken over the business and it is not the same anymore.
Fri, Jan 29, 2010 10:32 PM
Mike Walsh
I assumed that retainer was some obsolete part of early chambers as I've never seen one and never gave it another thought. Next time I'll be a little more careful.
Sun, Jan 31, 2010 12:10 AM
