D4 7u Pilot motor fuel tanks
Bellyman
Send a private message to Bellyman
Does any one make a plastic tank for these bloody petrol pilot motor tanks? , Our keeps rusting up all the time and is a pain in the arse or should I just make my own ??http://www.acmoc.org/bb/images/icons/thumb.gif
Tue, May 3, 2016 1:49 PM
cheshire cat
Send a private message to cheshire cat
I've never had a problem once they've been cleaned out properly !!!!
use thinners and if still mucky small stones / grit give it a good shaking....
I add a tiny bit of oil to the fuel as a preventive....👍
Tue, May 3, 2016 2:03 PM
Clean it good once and coat it inside. Several products available to do it with. I use one called RED KOTE. I think there is a POR 15 product and there are others.
Wed, May 4, 2016 12:48 AM
old-iron-habit
I use Redcote in one of mine and then have used chain saw mixed premium gas since. Knock on wood but so far so good. I put about 30 ea 3/8 nuts in it first and shook it for a few days every chance I got. I've heard of them being bolted to a spoke om a tractor wheel and being rattle cleaned while doing fieldwork. Put a threaded plug in the bottom before you pour the redcote in so you dont fill the threads.
Wed, May 4, 2016 1:17 AM
Reply to old-iron-habit:
I strapped my D2 tank to my lawn mower and added nuts,bolts,sand and water and it came out really clean-then redcoat it
Wed, May 4, 2016 3:50 AM
blwatson
Send a private message to blwatson
Reply to dpendzic:
Muriatic acid works very good to clean out the tank.. Then clean with baking soda solution to neutralize the acid. Then recoat and let dry for several weeks before adding fuel. Letting the coating cure completely is very important.
Wed, May 4, 2016 9:16 AM
caterpillar13
Reply to blwatson:
like said use bolts and shake, then if you dont use the cat much i run chain saw gas in them and keeps the carb. and tank from rusting much
Wed, May 4, 2016 10:15 AM
frochevy
Send a private message to frochevy
Reply to caterpillar13:
I've thought about making a tank out of Stainless Steel. Are the D4 tanks the same as the D2 tanks? I have a D2 3J that has a Nasty tank...
Thu, May 5, 2016 12:05 AM
STEPHEN
Reply to frochevy:
POR 15 worked well for me
Thu, May 5, 2016 12:07 AM
