D4 7U parts diagram needed
Showing 1 to 6 of 6 results
Reisingerweld
Send a private message to Reisingerweld
hi guys can someone post a better image of page number 212 in the D4 7U27570-4407 form ue032523 parts book. The image in the technical library is very difficult to read.Im pretty sure i only need page 212 but if you wouldn't mind posting the other pages of the low gear groups it would be appreciated.
Fri, Nov 5, 2021 8:34 AM
d2gary
Hope this helps [attachment=65223]20211104_185131.jpg[/attachment][attachment=65224]20211104_185103.jpg[/attachment][attachment=65225]20211104_185118.jpg[/attachment]
Fri, Nov 5, 2021 8:55 AM
Reisingerweld
Reply to d2gary:
Thank you, so I understand that there is a gear not shown in page 212 ( on the upper shaft) but can someone explain how you get a 2 speed reverse out of that specific trans with only one reverse gear on the lower most shaft as that would be the reverser assembly?
Fri, Nov 5, 2021 9:07 AM
d2gary
Page 213 shows the double reverse gear group
. [attachment=65226]20211104_200034.jpg[/attachment]
Fri, Nov 5, 2021 10:05 AM
Reisingerweld
Reply to d2gary:
Yea so what I'm trying to figure out is if I can use a transmission out of a later serial number machine turns out I can't because the actual machine housing/frame is different (later housing doesn't have reverser hole in side of housing) so the trans assembly in page 213 is like what I have and obvious as to how you get 4 forward and 2 reverse but the trans on page 212 still confuses me as to how you can get power flow through a single reverse gear but yet have a 2 speed reverse
Fri, Nov 5, 2021 10:11 AM
Deebo
Librarian
Thank you received: 105
Sorry that image was so bad. I’ve uploaded a better copy of that parts catalog. Should give a clearer view of the page. While I’m on the subject if anyone spots manuals that are unreadable let me know and I’ll try and obtain a better version for the Tech Library.
Regards,
Tony
 [attachment=65265]A6ADD9E8-E21C-49C5-8DFB-8F10A5208901.jpeg[/attachment]
Sun, Nov 7, 2021 3:11 PM
Reisingerweld
Reply to Deebo:
Regards,
Tony
Awesome, I'll keep my eye out thanks so much
Sun, Nov 7, 2021 3:19 PM
