D4 7U part number
D4 7U part number
1S1K
Send a private message to 1S1K
Can someone please tell me the correct Part number for a fuel pressure gauge on a D4 7U 18212, I have repair manuals but no parts book yet and my gauge is broken, also the water temp gauge would be great if possible too. Thanks!
Sat, Mar 8, 2014 12:27 AM
my book shows 7F9084 for fuel pressure and
4F6220 for heat indicator
Sat, Mar 8, 2014 1:46 AM
These are from D69U catalog, but should be the same as your 7U (though numbers probably have been updated)
Fuel pressure gauge 6B6158 or may be updated to 3H3344..........the face of the gauge changed over the years.
Water temperature 4F8238 or may be updated to 5H2954 a standard 2" diameter gauge with an adapter ring and 4 screws to install it in the housing. Again, the face design changed over the years and ir appears the overall diameter changed as well. I know the oil pressure gauge was updated that way.
Sat, Mar 8, 2014 1:51 AM
There's a whole string of replace by numbers.
7F9084 RPB 3H2906 or 5M1065 = 2H6790 or 3H3080 with 3H2906 equal to a Stewart Warner #44422
4F6220 RPB 4F8238 RPB 7H6947 RPB 9H1262
Both require the 5B9683 four screw hole adapter.
Sun, Mar 9, 2014 12:36 AM
cAT IS SOMETHING ELSE
3h3080---1w5353--$47.17 with seal 6v3507--$2.21 with adapter 5b9683-$5.59
9h1262---200-5231---$66.82---with seal 6v3507--$2.21 with adapter 5b9683--$5.59
Sun, Mar 9, 2014 4:42 AM
