D4 7U Part
D4 7U Part
Showing 1 to 6 of 6 results
Hank
Send a private message to Hank
Hi all,
    It has been a long time since I have been on this site, but I need to know what I need so I can replace the part. I looked in the part manuals for the D4 7U but did not see the part I need in the manual.  My D4 is a 7U that was built around October of 1955, the same month and year I came off the line too. The enclosed picture shows the broken part. I do not know what the name of the part is, if you know please tell me. If you have a replacement part like the one I need, I would be more then happy to purchase it. Thank you.
Hank
Sat, Oct 22, 2022 8:10 AM
D4Jim
I think they refer to it as an auxiliary control lever and was an added accessory on most models. There was a handle or knob where the threads were broken off and one could weld or braze a treated rod to the end and fix it. They are sometimes hard to find. Just an extra handy handle to control the injection pump/throttle.
PS:  Go the wanted and for sale forum and ask for the Governor auxiliary control lever.  That is how I found one for my D4.
Cats Forever
Sat, Oct 22, 2022 9:32 AM
rax200
Reply to D4Jim:
Hi Hank,
The level in in the parts book under "fuel pump and governer control" part number is 2h4376 the knob is 7f8092.
Regards
Sat, Oct 22, 2022 9:48 AM
josh
Thank you received: 14
Reply to rax200:
Hi Hank,
Regards
Looks to me like there is enough of the lever left, that you could just cut some more threads and put on a new knob.
https://www.ebay.com/itm/301760939703
Sat, Oct 22, 2022 10:01 AM
D4Jim
Reply to D4Jim:
I think Josh has a great idea to cut some more threads and get a knob. You might have to grind a little off to keep the proper OD on the threads but it looks like it wouldn't be much. Good luck.
Cats Forever
Sat, Oct 22, 2022 1:30 PM
Thank you received: 288
Reply to D4Jim:
I have done as others mentioned. Use a die and thread enough to add the knob;welded a "leg" from a discarded lever/control; cut off the head of a NF bolt and welded on as well.
Yes, because they are a pain to source at times, so you do what works at the time! JM
Sat, Oct 22, 2022 9:47 PM
Thank you received: 54
i dont know about that knob, but the handles as used on the clutches are still available via the dealer. i would go to the local industrial supply or auto parts joint and get a generic knob and a bit of all thread to suit and weld it to the governor lever.
Sun, Oct 23, 2022 3:58 PM
