D4 7U no spark on pony......magneto?
Showing 1 to 10 of 33 results
Eganx
Send a private message to Eganx
I went to fire up the dozer yesterday and found the pony had no spark. I pulled the cap off the magneto and the point look OK. However I'm not familiar with magnetos. Is there anything specific I should look for?
It appears the ignition on off switch just goes to ground as it only has one wire going to it and then another wire going to the body of the switch which is in contact with the bracket that holds it. Is that correct?
Is there anyone out there who rebuilds these thing?
Thank you - Egan
Tue, Aug 29, 2017 1:53 AM
7upuller
Hey Eganx,
Sometimes the on/off switch goes bad. Yes, it's only one wire going to ground. Remove the wire from switch and try to see if you get spark without the wire hooked up. If you do, you proved that switch went bad. Simply first step...
Tue, Aug 29, 2017 2:29 AM
Eganx
Reply to 7upuller:
Hey Eganx,
I had considered that. I did check the connection of the wire to the stud on the magneto, and it was a little loose for my liking, but tightening it didn't solve the issue. I'll try bypassing the switch since you've confirmed it just goes to ground. I've got my fingers crossed!
Tue, Aug 29, 2017 3:53 AM
JDcat
Send a private message to JDcat
Reply to 7upuller:
Hey Eganx,
If your mag is an American Bosch MJK series, check the brushes. When the cap is off, there will be three brushes with springs. My pony motor had no spark, and when I pulled the cap, two brushes had broken off. Individual springs are available from Florin Tractor.
John
Tue, Aug 29, 2017 4:01 AM
Machias cat
Send a private message to Machias cat
Reply to JDcat:
John
The points may look clean but the contacts need to be spotless and provide very low resistance when closed. A few passes with a fine grit sandpaper and then a few cleaning passes with white paper through the points should remove any contaminants and provide good conductivity.
Dirty points are the number one failure mode i have experienced with these magnetos. Easy fix.
Tue, Aug 29, 2017 5:38 AM
greengiant
Send a private message to greengiant
Reply to Machias cat:
[quote="Machias cat"]The points may look clean but the contacts need to be spotless and provide very low resistance when closed. A few passes with a fine grit sandpaper and then a few cleaning passes with white paper through the points should remove any contaminants and provide good conductivity.
Dirty points are the number one failure mode i have experienced with these magnetos. Easy fix.[/quote]
we vintage shortwave radio collectors/restorers use De-Ox-Id or some similar brand to clean electrical contacts. I used it on my D2 points and got a nice fat spark from the previously dead mag.
Tue, Aug 29, 2017 5:48 AM
greengiant
[quote="Eganx"]I went to fire up the dozer yesterday and found the pony had no spark. I pulled the cap off the magneto and the point look OK. However I'm not familiar with magnetos. Is there anything specific I should look for?
Thank you - Egan[/quote]
It's a "kill switch" wire. you want it open (not going to ground) for a spark, only going to ground for "off." counter-intuitive.
Tue, Aug 29, 2017 5:55 AM
Eganx
Reply to greengiant:
Cut the switch out of the loop.....no spark
So the magneto name plate says "standard magneto xh1907"
So would this be an aftermarket magneto? Everything looks quire fresh in there too. Its definitely been gone through in the last decade or two.
I didn't see any brushes to speak of.
Tue, Aug 29, 2017 8:38 AM
STEPHEN
Reply to Eganx:
[quote="Eganx"]Cut the switch out of the loop.....no spark
I didn't see any brushes to speak of.[/quote]
Then you have a Wico magneto. That mag has the best parts availability as it was the latest type , along time ago.
Tue, Aug 29, 2017 8:48 AM
Reply to STEPHEN:
Change the condenser/capacitor as it is the second easiest thing to do after cleaning the points.
Keep it simple, its not totally dead yet!
Tue, Aug 29, 2017 9:01 AM
Eganx
Reply to drujinin:
I got a flat nail file and I'm going to clean the contacts one more time. I also want to check the timing. I was careful to put the rotor back in the same position every time, but there is a chance I put it one tooth off. I see there are two teeth on the drive gear with a chamfer on them. I'm hoping those line up with a mark on the rotor.
If all that fails I'll move to replacing the condenser.
Fri, Sep 1, 2017 1:36 AM
