D4 7U info request
D4 7U info request
Showing 1 to 6 of 6 results
Relic
Send a private message to Relic
Im about to prurchase a D4 7U serial number 7U 39998 and was hoping someone could reply with a build date. If purchased i'll put some pics up.
Fri, Oct 28, 2022 10:20 AM
Kurt Bangert
Thank you received: 7
I believe 1957 - we always want pics!!
Fri, Oct 28, 2022 10:25 AM
Relic
Reply to Kurt Bangert:
Would it have a wet clutch at that vintage?
Fri, Oct 28, 2022 10:28 AM
Kurt Bangert
Reply to Relic:
It could have, both dry and wet were available
Fri, Oct 28, 2022 10:32 AM
Kurt Bangert
In the 1950's and 60's both wet and dry clutches were available as well as direct electric start or pony start. I'd look at the parts books in the Library section and study the wet and dry clutch setups and see if you can't determine it from there. Both my D4's are dry clutch, can't tell you what to look for on a wet clutch from memory! I just posted a couple of D4 vids on YT, won't help you much, but may be interesting.
Fri, Oct 28, 2022 10:37 AM
PNW.Hillbilly
Send a private message to PNW.Hillbilly
It's a 1957, good luck!
Fri, Oct 28, 2022 12:05 PM
Relic
Reply to PNW.Hillbilly:
Thanks, we'll see how it goes.
Fri, Oct 28, 2022 4:09 PM
