D4 7U identity
D4 7U identity
Showing 1 to 9 of 9 results
Sprucegum
Send a private message to Sprucegum
I have a tag on the side of the engine that reads "tractor number 2970"
When I called my local partsman for a new fanbelt he tells me that number don't jive with his books.
Is there another number somewhere I should be looking for?
Thu, Jan 15, 2009 7:58 AM
gemdozer
The serie number is on left side motor near the poney transmission and on left side back stering cluch housing.
Thu, Jan 15, 2009 8:12 AM
Sprucegum
Reply to gemdozer:
Thanks Gemdozer, left side by the pony is where I found the tractor number. I will have a look by the steering clutch housing to see what matches.
It'll be 2 weeks before I get a chance to go look though 😞
Thu, Jan 15, 2009 8:55 AM
You might try giving him "07U2970" since all the newer machines have 2 digits before the letter, he may need the zero to fill the space.
Some of the young guys won't go get on the microfiche machine to look up parts for the old machines.
Thu, Jan 15, 2009 9:03 AM
Willie
Reply to Sprucegum:
The number will start with 7U????? so if that nuber you found on engine stats with the 7U your tractor was built in 1948. Also I wouldnt part much into what a parts guys says most are too lave to do any lookingup they want you to do all the work and just give them a part no. and it is 4F7956
Thu, Jan 15, 2009 9:05 AM
Willie
Reply to Willie:
I forgot that number is good for every 7U-6U made
Thu, Jan 15, 2009 9:06 AM
Sprucegum
Reply to Willie:
Would that 4F7956 be the number for the fanbelt?
Thu, Jan 15, 2009 11:24 AM
catcrazy
Send a private message to catcrazy
My D4 is 07U2777, That's not that far apart. Haven't got around to doing anything with the D4 yet, possibly this summer needs a little TLC & have to mount a blade ( 6 way ) have to find a few parts first & a winch. Well good luck & thought that I would say hello & happy yellow dreams.
Thu, Jan 15, 2009 12:07 PM
Willie
Reply to catcrazy:
That is the part no. for the fanbelt for all the D4 7Us and 6Us 4F7956
Thu, Jan 15, 2009 1:01 PM
Sprucegum
Reply to Willie:
Thanks again guys 😊
Fri, Jan 16, 2009 11:20 AM
