D4 7U Hyster Winch
D4 7U Hyster Winch
Showing 1 to 10 of 38 results
ginger james
Send a private message to ginger james
Hi, could anybody please tell me what model of hyster towing winch would be on a late 1940's D4 7U s/n not known.As i understand there are two kinds a
D4N towing winch and a D4 towing winch and does anybody know what the differance is. Thank You,
Regards
ginger james
Tue, Oct 20, 2009 2:25 AM
Most of the difference is in the controls. The D4 was earlier and had a control arrangement that mounted under the seat....more suited to the side tank model tractors. The D4N is a later unit and has fender mounted controls more suited to the seat tank models. The D4N also weighs a little bit more.
Tue, Oct 20, 2009 3:38 AM
OzDozer
There are only minor differences between the Hyster D4 and D4N towing winches. The biggest differences are in the full drum speed, and the maximum line pull, with the D4N having an increased line pull over the D4, and a slight difference in full drum speed. I cannot see any difference in weight between the two.
The Hyster D4 pulls a maximum of 15,400 lbs .. the D4N pulls a maximum of 17,020 lbs.
The D4N had the option of a PTO for a rear mount hydraulic pump, which was built in at the factory. I understand this to mean the PTO could not be fitted later.
The D4 is easily identified by having "D4" cast into the winch sideplates .. the D4N has "D4N" cast into the side plates.
The parts/operator/fitting instruction manuals are available from the Allied Winches site. If you examine the parts sections closely, you can see the difference in the control linkage setup as OM described.
D4 manual .. http://www.alliedsystems.com/pdf/Winch/Manuals/599181W.pdf
D4N manual .. http://www.alliedsystems.com/pdf/Winch/Manuals/599185W.pdf
D4 specification sheet .. http://i33.tinypic.com/29m3q10.jpg
D4N specification sheet .. http://i37.tinypic.com/154iy6w.jpg
Tue, Oct 20, 2009 8:28 AM
Reply to OzDozer:
We have some variation in specifications.
Tue, Oct 20, 2009 9:36 AM
OzDozer
OM - Your D4 winch spec sheet appears to be a real early spec sheet, possibly early WW2, or maybe even just prior to WW2? Is it dated?
My D4 Spec sheet is dated 3/46, and the D4N spec sheet is dated 10/47. I was trying to get spec sheets dated close to the D4 7U release date of early 1947, and which would more closely relate to any original fit winch.
Tue, Oct 20, 2009 10:30 AM
ol Grump
Reply to OzDozer:
Besides the D4N having some slightly larger bearings inside, another difference is is the braking system. The D4 has a system that uses a brake band and the D4N has brake shoes. The D4N uses a a brake adjuster that's similar to the adjusters on "S" cams while the D4 has the adjuster inside the right hand side cover. Both were available with under seat controls or fender mounted controls, both had brake levers that were fender mounted.
As I recall, the D4 is more suited to the J and T models while the D4N was for the U models. They both mount the same and I've had a 7U that had the D4 winch. .worked well as long as I had the brake band adjusted properly.
Tue, Oct 20, 2009 7:56 PM
ginger james
Reply to ol Grump:
Thank you, To all of you for replying it was a great help.
Regards Ginger james
Sat, Oct 24, 2009 2:01 AM
checho
Send a private message to checho
Reply to OzDozer:
Some one knows what’s the difference between the Hyster D4N, the D4D and the D4E winches? I found the D4N spec sheet, and the manuals at:
http://www.alliedsystems.com/pubs/pubs-winch.htm
But I want to know which one has more pulling capacity; the D4N I believe has 17,020 lbs.
[quote="OzDozer"]There are only minor differences between the Hyster D4 and D4N towing winches. The biggest differences are in the full drum speed, and the maximum line pull, with the D4N having an increased line pull over the D4, and a slight difference in full drum speed. I cannot see any difference in weight between the two.
D4N specification sheet .. http://i37.tinypic.com/154iy6w.jpg[/quote]
Fri, Sep 2, 2011 2:48 AM
Reply to checho:
The D4D is 19,200 lbs pull (bare drum)
The D4E is 25,800 lbs pull (bare drum)
Fri, Sep 2, 2011 3:08 AM
checho
THANKS, I have buy a d46u with a d4d winch, the tractor dosent run but I have repair a d47u that looks brand new and Im planing on instaling the d4d winch on it for logging.Where did you get that pull capacity info? thanks again
Francisco
Fri, Sep 2, 2011 10:33 PM
checho
Reply to checho:
Francisco
sorry I mean i have buy a d46u whit a d4n hyster winch
Sat, Sep 3, 2011 9:48 PM
