D4-7U hydraulics will not hold blade up slowly drops within a minute or two
Showing 1 to 10 of 18 results
talley925
Send a private message to talley925
Hello,
The hydraulics will not hold the blade up on the D4 it slowly drops over a minute or two. I do not see any hydraulic leaks and the hydraulics operate smoothly and can lift the dozer but it had been sitting for 15 years. I see what looks to be a manual bypass valve and its set to centered, and there are two quick connections in the back of the CAT. Should this valve be centered and would it cause this? I haven't attempted to move the valve yet and wanted to hear what others think first.
Tue, Jun 4, 2019 1:17 AM
bursitis
do you have one lever or two?
Tue, Jun 4, 2019 3:07 AM
Thank you received: 46
Reply to bursitis:
Diverter valve handle should point to the right for dozer operation, straight back for rear implement operation.
Blown hydraulic ram piston seals are most likely cause of leak down.
Get a part number off the cylinders.
Tue, Jun 4, 2019 6:24 AM
talley925
Only has one lever, I'll move it to the right and get the part numbers as suggested. Should I try that Lucas hydraulic booster with stop leak?
Tue, Jun 4, 2019 9:31 AM
bursitis
Reply to talley925:
one lever. then OM suggestion would be right on. do the packings leak around the polish rods?
Tue, Jun 4, 2019 9:45 AM
talley925
Reply to bursitis:
Well, I did not see any visible leaks after about 30 minutes of use and when raising or lowering it operates smoothly.
Tue, Jun 4, 2019 8:08 PM
diesel583
Send a private message to diesel583
Reply to talley925:
My 6U was bypassing the piston seal, had the same leak down. No outside leaks. Rebuilt the cylinders and everything is great
Tue, Jun 4, 2019 10:29 PM
oldtanker
Send a private message to oldtanker
Reply to talley925:
As old magnet says most likely cause will be an internal leak around the piston seals. I don't know what medium was used for those seals. If rubber a hydraulic stop leak may work. How that stuff works is it "attacks" the rubber causing it to swell. At best it's a temporary stopgap measure. Mechanic in a bottle stopgap measures may work for a time but are not going to last like a proper repair. They may also cause excessive wear or destruction of parts in the system.
Rick
Tue, Jun 4, 2019 10:40 PM
talley925
Reply to oldtanker:
Rick
Sounds good, I'll start researching on how and what's all involved to remove and replace the bad piston seals.
Tue, Jun 4, 2019 11:49 PM
STEPHEN
Reply to talley925:
There are at least two different kinds of seals, one of them are composite rings with a stepped end gap. It is possible to use a modern piston seal and make a new groove in the middle of the piston if needed.
Wed, Jun 5, 2019 4:48 AM
bursitis
Reply to STEPHEN:
around here most machine shops will rubuild hydraulic cylinders. they will probably use oem parts if you order them and supply.
Wed, Jun 5, 2019 5:48 AM
