D4 7U Hydraulic hose adapters
power stroke 99
Send a private message to power stroke 99
I damaged the lower right hand hose flange adapters (Snapped one of them off :doh:and bent the other) for the hydraulic blade lift. A stump was caught on the track and I did not notice until I heard the line break. Does anyone have a spare set or know where I can find a set?
Mon, Sep 8, 2014 8:00 AM
power stroke 99
Does anyone have the size of the ID and OD of the hose that is required?
Mon, Sep 22, 2014 10:05 PM
Reply to power stroke 99:
Hose sizes have changed somewhat from back in the day but current 3/4" ID two wire hydraulic hose works with a little fight, maybe a dip in some hot water and a little lube to assist.
Tue, Sep 23, 2014 2:35 AM
power stroke 99
Thanks,
That is what I was thinking on the hose size but was not sure if I should get 2 or 4 wire for the clamp to work properly.
Tue, Sep 23, 2014 6:33 AM
old-iron-habit
Thanks,
[quote="power stroke 99"]Thanks,
That is what I was thinking on the hose size but was not sure if I should get 2 or 4 wire for the clamp to work properly.[/quote]
I would go with the two wire. A little easier to work with and the pressure rating is still well above the old Cat pressures.
Tue, Sep 23, 2014 7:10 AM
