D4 7U heating
D4 7U heating
shelbysharpd4
Send a private message to shelbysharpd4
I've had overheating problems on my D4 so I finally broke down and pulled radiator and took it apart, yuck. It was plugged up. I contacted White Tractor in Missouri because they have helped me on hard to find parts, front idler upgrade and a few other things. They guy told me he would get me a 3 inch core. He said I had the 2 1/4 core. He was right. My grandpa replaced this when I was about 12, 1980, and he had trouble during the summer months with it running hot. I bolted in the new core, which had an extra row of tubes, and finally got to work it today. Cleaned out 1 1/2 miles of fence row pushing small trees and leveling up. The temp gauge never got any further than 3/4 in the normal range. Wow, the core I pulled out had the correct Cat part number but it never cooled right. It wasn't big enough. Grandpa would be proud.
Sun, Jul 21, 2013 9:33 AM
Thank you received: 34
Hi shelby,
good to hear you got the correct core to fix your problem.
At The Dealer once I had a used imported, from England, gen set that overheated on 100F + days.
Checked everything including Cat part no tag on the core and it APPEARED to have the correct core fitted.
After many $$$$'s testing a tube and fin count said otherwise !!!
I found a radiaror Co tag hidden on the core and the penny droped as to a possible incorect core with the correct P/No.
So we need to be careful of what is actually fitted by tube and fin count not just P/No tag say so.
Sun, Jul 21, 2013 9:51 AM
shelbysharpd4
Reply to edb:
Hi shelby,
It was 95 degrees yesterday and it never once got warm. I wonder how many more of these old cats this happened to.
Sun, Jul 21, 2013 10:07 PM
