d4 7u governor removal
Showing 1 to 10 of 32 results
Bigfish
Send a private message to Bigfish
How do i remove the governor on a d4 7u dozer. need to remove the governor to get the clutch out.
Sat, Feb 16, 2019 11:50 PM
Remove nuts and bolts.
Sun, Feb 17, 2019 1:54 AM
D4Jim
Thank you received: 12
Should be able to get it out by only removing the back governor cover that's next to the clutch and not remove the entire governor. You will also need to remove the clutch cover to get it out. This is of course after you loosen the pony and raise it an inch or two. Might be able to find a manual and post pictures if you need it.
Cats Forever
Sun, Feb 17, 2019 4:03 AM
gemdozer
Reply to D4Jim:
D4 JIM is writh you also need to removed the cluch lever assembly and removed rear cluch housing 2 screws from the inspection plate big motor for turning the cluch housing and pull it out and dont forget to angaged the pinion it give you more room.
Sun, Feb 17, 2019 4:45 AM
7U1216
Send a private message to 7U1216
Reply to gemdozer:
Welcome to the forum
There’s (if I remember) a couple bolts on the governor down beside the block you won’t see if you haven’t washed it off nice. Dirt builds up in between the block and the gov and unless you’ve had one off befor you won’t know they exist...might be what your hung up on.
Sun, Feb 17, 2019 12:23 PM
Bigfish
Reply to 7U1216:
I removed governor cover and the end plate on the clutch. Also removed the clutch engagement lever. Clutch still won't come out. I'll look for the bolts between the governor and the engine block.
Sun, Feb 17, 2019 11:41 PM
gemdozer
Reply to Bigfish:
You have to used some lubrifient like WD40 between the cluch housing and the motor rear housing because the cluch housing have a big seal and must be dry on and did you removed the 4 cap screws before try to removed the cluch housing and removed the screws from the inspection plate on big motor and try to turned the cluch housing on left and right side he should come out,
Mon, Feb 18, 2019 2:28 AM
ag-mike
Reply to gemdozer:
someone should make a video of trying to remove a d4 pinion clutch housing.
this 1 i had to remove governor, maybe i'm full of it but sometime u gotta do what u gotta do.
[attachment=52758]SAM_0214.jpg[/attachment]
Looking at this photo i didn't take the bearing cap off the p-clutch housing because i didn't think it was going to come out with it off. someone should confirm or refute this detail.
Mon, Feb 18, 2019 2:39 AM
Reply to ag-mike:
[quote="ag-mike"]someone should make a video of trying to remove a d4 pinion clutch housing.
Looking at this photo i didn't take the bearing cap off the p-clutch housing because i didn't think it was going to come out with it off. someone should confirm or refute this detail.[/quote]
I always removed the governor also.
Mon, Feb 18, 2019 6:34 AM
gemdozer
The cluch housing is coming out with out removing the governor but the rear cover from cluch housing have to be removed and if somebody have the servicemen's reference book form 30522,1 page 275 you could see the illustration removing cluch and starter pinion .am ignorent for sending picture.
Mon, Feb 18, 2019 7:27 AM
Reply to gemdozer:
7U1293 has one piece clutch/transmission cover.
Mon, Feb 18, 2019 8:16 AM
