d4 7u fuel tower drain
Showing 1 to 7 of 7 results
Walter
Send a private message to Walter
I have looked at previous posts looked at pictures but no luck. I have pipe with cap right behind fuel line and small plug even behind that. if you put air in small plug hole you get a little air in tower but no drainage. tried coat hanger . tower needs cleaning out but how. any help appreciated walter.
Sun, Apr 28, 2019 7:18 PM
Take the hood off, remove top covers accessing the filters and clean from the top.
Sun, Apr 28, 2019 7:39 PM
Walter
Reply to drujinin:
hood is off been using suction gun. guess I will just keep doing that
Sun, Apr 28, 2019 8:38 PM
Reply to Walter:
Have you removed the filters and scraped out all of the crud that settles in the bottom?
Sun, Apr 28, 2019 8:57 PM
STEPHEN
Reply to dpendzic:
You might need a long screwdriver to get the solidified sediment loosened
Sun, Apr 28, 2019 9:17 PM
Walter
Reply to STEPHEN:
does not really have crud just old nasty fuel. going to keep using suction gun maybe rag to soak up fuel. got new filter kit from florin.going to install Monday.thanks for input.
Mon, Apr 29, 2019 5:40 AM
If it won't drain, there is solidified sediment in the bottom of the filter housing. It may be easier to poke up through the drain pipe than to poke around from the top and find the hole. A screwdriver is a good tool, the last one I did, I had to chip the crud out of the hole, twisting and reaming it out with the screwdriver.
Mon, Apr 29, 2019 9:18 AM
ag-mike
this, couple times is my experience.
Mon, Apr 29, 2019 9:28 AM
