D4-7U fuel pump/rack oil seal
Breadler
Hello everyone,
I am replacing the OEM leather seal that surrounds the drive shaft for the fuel pump(s) cam. With the new seal being a modern lip type seal, am I orienting it to keep the oil out of the fuel tower, or keep the diesel out of the pump assembly? I am guessing the latter of the two. Sounds like a peanut butter cup commercial…..lol
Thanks much,
Breadler
D5C, D4-7U, D2-5U, D2-5J
Sat, Nov 8, 2025 4:20 AM
Thank you received: 54
i would think diesel out of the oil.
Sat, Nov 8, 2025 6:51 AM
ChrisE
Thank you received: 41
Can you fit two thin seals in to seal each way.
Sat, Nov 8, 2025 10:55 PM
Breadler
Only room for 1 replacement. The original was a wide leather seal, so there was no indication of direction. The replacement has the same width, but is of model lip style.
Sun, Nov 9, 2025 3:50 AM
D4Jim
The seal keeps the diesel fuel out of the pump / oil. The diesel fuel is under pressure from the transfer pump. Your guess is correct.
Cats Forever
Sun, Nov 9, 2025 5:00 AM
