D4 7u fuel primer pump
Showing 1 to 10 of 11 results
kylerose
Send a private message to kylerose
Just wondering if anyone has a part number or availability of the hand operated fuel primer pump that would have come on a d4 7u with electric start. I've been looking around and can't find the information I'm looking for . Any help would be appreciated thanks
Kyle
Thu, Jan 21, 2016 9:55 AM
Hillbillybjopkr
Send a private message to Hillbillybjopkr
there is a picture of the priming pump in my operations manual.....bottom left corner of the pic has a number T21012 not sure if that is pic number...or maybe a part number....hope this helps
Thu, Jan 21, 2016 10:30 AM
daron
Thu, Jan 21, 2016 10:42 AM
Mike Meyer
Thank you received: 5
Reply to Hillbillybjopkr:
My 7U27570-Up book shows a 5H9877 Fuel Priming Pump Group on tractor 7U28232 for use with 24 volt starting or 5H9869 Fuel Priming Pump Group for 24 volt starting with fender mounted fuel tank, if you need individual part numbers of the unit sing out. I had a quick look on Parts search and none of those 2 numbers show as available anywhere though searching individual parts shows availability, look for
4F7762 Base
2H2483 Barrel assembly (pump)
7B8633 Cap (of pump)
7B8517 Handle assembly
It looks IHM Used Parts might have bits you need, try them on 888 53528 one seven
Good luck
Mike
Thu, Jan 21, 2016 10:52 AM
kylerose
Reply to daron:
OM added a self built priming pump and discussed it in this thread. The diagram has disappeared into the ether.
http://www.acmoc.org/bb/showthread.php?21347-Setting-up-fuel-priming-and-filtration-for-the-Diesel-engines&highlight=hand+priming+pump+old+magnet
This has the Cat parts page from edb.
http://www.acmoc.org/bb/showthread.php?16817-D4-7U-primer-pump-parts&highlight=hand+priming+pump+old+magnet
Daron
Thanks I've been looking at those brass pumps wondering if that's the easiest option . OM if you read this , would you by chance be able to post the missing pictures from the link page . Thanks
Thu, Jan 21, 2016 11:01 AM
kylerose
Reply to kylerose:
Thanks Mike Meyer I'll look around to see if I can find those parts
Thu, Jan 21, 2016 11:05 AM
Thank you received: 19
Reply to kylerose:
Those original hand priming pumps are not worth fixing unless your bent on original. The pump barrel and piston rod is steel and usually are badly corroded. In that state the barrel just tears up the plunger.
Here's the missing pictures, choice of fuel gauge or hour meter in the bracket or just the pump.
I see the BB is back to loading picture sequence backwards again. Worked right for a while.
Thu, Jan 21, 2016 11:23 AM
kylerose
Thanks OM I'll try something along the lines of that when I get the time to do it
Thu, Jan 21, 2016 12:07 PM
candoman
Send a private message to candoman
Hey Old Magnet I cant get those pictures of the primer setup you did.Could you repost them?It would be much appreciated.I purchased one of those brass pumps on ebay but could use a little help hooking it up. It has a check valve in the inlet side of the pump I'm installing it on my 1953 serial number 7/U 25012  Thanks Again!
Sun, Mar 10, 2024 10:14 PM
Reply to candoman:
Was done as part of a prefilter installation....
  [attachment=75611]Prefilter #1.JPG[/attachment][attachment=75612]Prefilter #5.JPG[/attachment][attachment=75613]Prefilter #2.JPG[/attachment][attachment=75614]Prefilter #3.JPG[/attachment][attachment=75615]Prefilter #4.JPG[/attachment]
Mon, Mar 11, 2024 5:31 AM
candoman
Thank You OM for posting those pictures.Thats a very neat install,I have purchased the same primer pump you have. I bought it on Ebay and it was listed as 9H2256 - Pump Assembly 7S1251 for Caterpillar.In picture #2 is the black knob by the pre filter a shutoff valve? Does it have to be shut when priming? In picture #4 is the black hose behind the injector pumps going to your fuel pressure gauge on your dash?
Mon, Mar 11, 2024 8:45 PM
Earlcoate Charity Open Day
