D4 7U Fuel Injector????
Showing 1 to 10 of 42 results
metisse1965
Send a private message to metisse1965
New to the ACMOC registered yesterday and sent my dues today. I've owned a D4 tracksvator for 30 years. Smooth tracks w 1/3 yard bucket. Would run it once or twice a year usually around my small farm. Keep it running and did normal fiddling with it.
However, due to the death of my mother four years ago and my father requiring daily care I have not been able to start my machine for four years. Its been stored in a pole building this entire time. My dad died in August of this year.
Two weeks ago I started the pony started and was purring along. I released the start lever on the compression release and engaged the starter pinion and pulled the clutch back to engage it. Motor turned and gained rpm, gave the aircleaner a shot of ether and flicked off the compression release to the run position. Diesel sputtered and ran briefly them quit firing. I tried several more attemts but nothing worked. Fuel pressure guage was in the white or no run position.
I ve got a maintence book so I emptied the fuel tank, drained the fuel injector housing and bought a new fuel fillter. Book sez open top and bottom vents on the fuel housing and the four fuel injector relief valves. Then to start the pony and turn the engine over w the throttle closed and compression release in the start position.
For you "Reasonable Knowledgeable People" is there a desired sequence for closing the vents? ie bottom housing vent first after no air bubbles, then top vent, then indivdual injector vents?
Anything else I should check? Any tips? Anybody else been there done that??
Wed, Apr 4, 2007 9:38 AM
You are on to it!
If you still have no gauge pressure look at the fuel bypass valve on the bottom of the fuel filter housing where the fuel line comes in. Should be held on with 2 bolts and if you remove the bolts, fuel from the tank should flow out in a good stream if the tank valve is still open. there's a spring in there that can rust away and break, and a button on top of it that can get crud on it and prevent it building good pressure. fortunately it will still run well if that is the only reason for the low gauge pressure. In other words there's plenty of fuel available, it just isn't at the normal pressure. If the filters are stopped up, the pressure is low, AND there's a shortage of fuel delivered so performance suffers.
Wed, Apr 4, 2007 10:45 AM
NZCat
Send a private message to NZCat
You are on to it!
Hello Guys
Not to hijack this thread, but how does the fuel guage work, my filters were changed but the guage stays stubbonly in the white ( the tractor runs well) - is it likely the guage has a fault, or could there be something else at play . . .
Thanks - Foster
PS I admire you for having the guts to look after your folks right through
Foster Price
Southland, NZ
D2-5U #10200
Wed, Apr 4, 2007 4:53 PM
SJ
Send a private message to SJ
NZ, pick up a calibrated gauge of not more than 40 lbs. & hook it temporary into the system even where the gauge is now & see what pressure you have. The original gauges only have run position etc. so with the calibrated gauge you should get maybe 15 lbs. idle & maybe as much as 25 lbs. more or less at high idle when things are normal with the system. CC gave you some useful info. to follow too.
Wed, Apr 4, 2007 7:03 PM
D4Doug
Send a private message to D4Doug
Reply to SJ:
I just changed my fuel filters the other day on my D47U and I first fill the filter housing with clean diesel, install the filters, and then bolt it up. I open the round knurled vent and open the vent at the top of the housing. When I start turning over the engine, the fuel will start flowing out the vents and then I close the top and then the side vent several times until I get good flow. If fuel pressure does not come up all the way, I then go to the injector housing and bleed it. In the past, I have had ice form and block the fuel from flowing and other disasters but I have had the best luck with opening just the filter housing vents and then moving to the injectors rather than opening all the vents. Hope you get it going.
Fri, Apr 6, 2007 11:01 AM
SJ
Doug you are right on with the way you do a bleed job & filter change so if all would follow this procedure it will work out best.
Fri, Apr 6, 2007 7:04 PM
dave morgan
Send a private message to dave morgan
Reply to SJ:
I agree with your basic idea, except filling the housing with fuel. It should be filled from the fuel tank of the tractor, hopefully filled before trying to bleed the system. Not a good idea to pour fuel out of a can into the fuel filter housing or in later models into the fuel filter itself. We can do it, but we take a chance of introducing small buggers into the system past the filters. I used to precharge filter housings, but I don't anymore. Pony motor will turn the main engine enough to build pressure in the fuel filter housing. Bleed air off the top at the bleed screw then work your way along the injector lines at the injectors. As mentioned, it helps a lot if the fuel tank is full. Our Cat pre cup engines start much easier with a mix of Power Service in the fuel. In cold weather the main engine will start with 20 seconds of preheat with Power Service, it takes more than 3 minutes without PS and the engine misses and smokes white. This is around 15 degrees F.
Sun, Apr 8, 2007 12:20 PM
SJ
Reply to dave morgan:
Dave if you fill the filter base before hand the fuel anyway has to go through the elements before it goes to the pump housing so the danger of getting unfiltered fuel to the system is about "O" so I can,t see where there is any worry about dirt getting in unless the cover etc. is not cleaned up before it,s put back together.We always did it this way at the dealer & the many years I did engines & others there too never saw one engine that ever caused a problem if it was done in a proper clean manner.
Sun, Apr 8, 2007 5:49 PM
Toolbox
Send a private message to Toolbox
Reply to SJ:
If the tractor has been sitting for this long, check to see if you have algae growing in your fuel from moisture. My 7U had some get started before I bought. I treated it to kill it and a glob of black snot plugged the fuel line coming from the tank to the transfer pump. It took a while to find that. Good luck.
Mon, Apr 9, 2007 8:27 AM
metisse1965
Reply to Toolbox:
Well fellows its Metisse1965 up here in Lapeer Michigan. I've been bleeding top and bottom vents on the filter housing. Took off air cleaning housing so I could spray WD 40 into the air intake manifold to oil up cylinders. Bleeding off injector vents. Went back bleed everything a half a dozen times. Fuel pressure guage still registers in the red almost to the white.
CCJersey and other " Resonably knowledgable individuals" is the fuel bypass valve on the bottom of the fuel filter housing have a glass dial w a old pocket watch style flip cover?
Machine is relucant to fire when I flip off the compression release. What is the safe amount of starter fluid to use. A fellow told me I could blow a head gasket if I got carried away w the ether.
With the vents open I get a steady stream of fuel not super pressure is this normal?
Mon, Jun 25, 2007 8:33 AM
metisse1965
You are on to it!
Does this "fuel bypass valve" have a pocket watch style glass window that opens and closes? Does it have a 1 3/8 cap on the end closest to the radiator? Could I take this off? To check the fuel flow?
Mon, Jun 25, 2007 8:38 AM
